4 members (TUTS 59, PAUL Berardi, 68ironhead, Peggy M), 120 guests, and 1 robot.
Topics128,130
Posts1,056,369
Members48,441
#146186 03/23/2006 5:15 AM
Junior Member
Junior Member
Hey everyone,
it looks like I am going to be purchasing a New Process 542GL from a Big Bolt that had a 427. Does anyone know if it would be like this:
R24
135
or like this:
135
24R
or some other oddball pattern, like the Spicer 3053?
Thanks in advance
1969 GMC K/2500 (w.i.p.)
#146187 03/23/2006 10:26 PM
Feel for the spring loaded reverse position that should give you a idea
#146188 03/23/2006 10:42 PM
Junior Member
Junior Member
I dont have it here yet, but from what I've read and searched my first pattern above is what it should be.
thanks for the reply kb
#146189 03/24/2006 12:19 AM
Ya know the NP or New Process...stands for Noisy Pieces dont yah...??? hehehehe
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#146190 03/24/2006 5:44 AM
Junior Member
Junior Member
Isn't that what old trucks are supposed to do? Its when they are quiet that I start to worry.
#146191 03/25/2006 7:18 AM
Isn't the ODD pattern, 2nd one above for an Overdrive? Can you get the brand, model and year of truck it is from? An owner's manual for that year would have the info, I would think.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#146192 03/25/2006 8:27 PM
Junior Member
Junior Member
It was from a 1984 (i think) Chevy C60 with a 427 tall deck. It is definitely a NP542GL, it is stamped on the id tag. 7.33 ratio-must be first gear, that is why i'm guessing its not an OD tranny. they usually had something more in the 6.00 or less range for 1st.
#146193 03/27/2006 3:14 AM
the shift pattern should be like this
R24
135
the only outher one I have ever seen like this
124
R35
was in my 54 international
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
#146194 03/27/2006 9:16 PM
I have a NP 540C in my 1964 Chevy C60 and the shift pattern looks like the one shown on the transmission page on my website...
Not sure if this helps or makes things more confusing...but I wanted to throw in my 2 cents smile smile smile
Burgie
1964 Chevy C60 w/ Garwood dump, 327 CID, New Process 540C 5-Speed w/ Chevy 15,000 lb. 2-speed rear axle
1966 Chevy C60 w/ 292 CID, Chevy 4-speed w/ Chevy 15,000 lb. single speed rear axle
[b]Burgie's 1964 Chevy C60 Restoration Site[/b]
#146195 03/31/2006 6:46 AM
Junior Member
Junior Member
Thanks for all the replies! It looks like the gold medal goes to Burgie. The shift knob agrees that it is indeed
L24R
35
thanks again!
#146196 03/31/2006 7:34 AM
Boy-that'd take me some time to get used to...
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#146197 03/31/2006 8:17 PM
Junior Member
Junior Member
haha, I didnt even notice that...shift the 3 and 5 over, so the 3 is under 2 and the 5 under 4. THEN its correct. I need more sleep, haha.
