5 members (Bill Hanlon, artinva, Hotrod Lincoln, RoadsScholar, 1 invisible), 98 guests, and 1 robot.
Topics128,078
Posts1,055,936
Members48,430
#146030 03/10/2006 4:43 AM
I have a '55 2nd series 6100 and there is a vacumme diaphram that pulls a small gearbox on the back of the speedo. It compensates for when the rear end switches from high to low so the mph will be correct. The diaphram is rotten and I cant find anyone who carries these, and I even contacted Stewart Warner and they say its unavailable.Any Ideas? By the way, this site has been the best thing to happen with my restoration project! Much Appreciation!
#146031 03/10/2006 5:07 AM
Hey, another Iowan! Can't help you with your question though, but I can sure welcome you to the Stovebolt. Welcome,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#146032 03/10/2006 5:23 AM
I
I Offline
Ya ,thats what we need more Iowa people. We could corner the market here.
You might be able to find that part by going to an older truck repair place. Seems like to me that this bladder is similar to one used in air brake systems. Welcome and good luck.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#146033 03/10/2006 11:06 PM
Riding in the Passing Lane
You might try K.C. speedometer in Kansas City. The do a lot of G.M. speedo repairs.
1972 Chevy c10 Cheyenne Super
#146034 03/13/2006 6:25 AM
If you can't find the correct part,you might look into using a vacuum pot off an old carburetor;they perform the same basic function,and most have long enough mounting brackets to enable you to re-bend one to fit where you need it to be.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#146035 03/14/2006 4:53 AM
Thanks for the ideas- I'm sure I'll get something to work, whether its the right part or some "improvising". I really only use high most of the time anyway.
