| | | Forums66 Topics128,066 Posts1,055,874 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 6 New Guy | | New Guy Joined: Feb 2006 Posts: 6 | I have a '55 2nd series 6100 and there is a vacumme diaphram that pulls a small gearbox on the back of the speedo. It compensates for when the rear end switches from high to low so the mph will be correct. The diaphram is rotten and I cant find anyone who carries these, and I even contacted Stewart Warner and they say its unavailable.Any Ideas? By the way, this site has been the best thing to happen with my restoration project! Much Appreciation! | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Hey, another Iowan! Can't help you with your question though, but I can sure welcome you to the Stovebolt. Welcome, Scott | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Ya ,thats what we need more Iowa people. We could corner the market here. You might be able to find that part by going to an older truck repair place. Seems like to me that this bladder is similar to one used in air brake systems. Welcome and good luck. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You might try K.C. speedometer in Kansas City. The do a lot of G.M. speedo repairs. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | If you can't find the correct part,you might look into using a vacuum pot off an old carburetor;they perform the same basic function,and most have long enough mounting brackets to enable you to re-bend one to fit where you need it to be. Speed | | | | | Joined: Feb 2006 Posts: 6 New Guy | | New Guy Joined: Feb 2006 Posts: 6 | Thanks for the ideas- I'm sure I'll get something to work, whether its the right part or some "improvising". I really only use high most of the time anyway. | | |
