Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (greenie-reddy, 1 invisible), 122 guests, and 5 robots.
Topics128,291
Posts1,058,585
Members48,492
Just wonderd how many of you have actualy hand cranked your truck.
I start my 46 all the time that way wen theres not qite anuff battery to turn it over and dont have any 6 volt vehicles nearby
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
I drove a 1924 Dodge for a couple of years,and hand cranked it until I got the starter/generator chain fixed. It was easy,only 4 cylinders with real low compression.
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
I've hand crank started my 38 1.5 ton, but mostly use the electric start. Heard too many stories of folks being injured by kick back. It is more of a novelty for me I have the crank so every once in a while i have to try it.
No!! But hand cranked a lot of old tractors. The MTA was the worse bust a normal mans arm easily. JD side wheel crank doesn't count. That was 2 easy. grin popcorn The Truth is Out There (Still have an old Farmall B we crank every once in a while)
have not hand cranked my truck, never really wanted to, it is enough just to reach for the foot-starter, now this morning I did have some trouble with my gas edger,, I hand cranked and gave up on it,,,,Fred
Redryder pix
My Hotrod
I noticed my '46 two ton has the spot for the hand crank, and a little snap on piece that pops off the grill to slide the crank into, but I never tried it.
Mostly because I dont have the crank!
You can bet that if i'd had the crank back before I got the flywheel ring gear replaced, i'd have tried it!
I was lucky the crank, lugwrench, and jack were still under the seat when I bought my truck.
Before I took my 40 GMC apart that is the only way I would start it. People really get a kick out of it. Starts first crank every time. Just make sure you leave your thumb out, like your hitch hiking, that way if it does kick back the crank will spin in your hand and not break your thumb
I've got a crank.. i keep it hanging in my garage along with my collection of rare hood ornaments.
I hand cranked the old 216 before I yanked it out, but it was beyond starting by that time.
Another quality post.
Real Trucks Rattle
I've got a 1936 Allis-Chalmers WC that has no choice, hand-crank only, because there's no starter motor. Electric start was "optional equipment" on that one!
Big Bolt Shop Curmudgeon
Nope!
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
i was looking down between the radiator and the fan and i noticed there is a spot for a crank but no hole for it to pass on out to the front for cranking
Hey Hotrod Lincoln,
I have a AC-WC Speed patrol (Road Grader) that's also hand ckank only. Have you ever seen an "Un-Styled" Speed Patrol? I've seen a few "Sryled" ones, but never "Un-Styled" I'm looking for info...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Junior Member
Junior Member
tried to hand crank my ´53 volvo t33 tractor,but the loader was in the way,so I couldn´t get enough "omph" to start it.
car nut for life!
