Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Forty9, Hotrod Lincoln, 55shaker, baldeagle, NJC), 51 guests, and 3 robots.
Topics128,005
Posts1,055,263
Members48,418
I woke up this morning thinking about the tires that are on my 1954 3100 5 window. It's mostly original with the 235 engine and 3 on the tree.
recent put new tires on my Mini Cooper Rally car, as I thought they were just getting too old, and I wanted a newer stickier compound. Never thought about the tires on the truck. The tires are the ones that were on the truck when I bought it 3 years back, and while pretty noisy they had plenty of tread, so I did not give it much thought.
I went out the the garage to see if I could tell how old they are. They are Cooper Discovery LT's but I was unable to find any DOT code on any of the Tires. From what I understand, DOT codes have been required on tires since 1971.
Since I can not find a DOT code, are my tires really like 50 years old?
Scary, as some days I do drive it like I stole it. Picture attached of the tire.
1954 Chevy 3100
If you drive Hiways on a regular basis then replace ASAP.
Did you look on both sides of the tire for the DOT info? They only stamp it on one side...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks Mike B, I had not thought of that. I was able to read code off of 3 of the Tires. None of them good.
(CJL492) (CLJ291)(CUB073) If I am reading it right, the two front tires are from 1992 and 1991, and the rear tire looks like it's from 1973? Really???
I attached the two picts of the ones that were easiest to read.
Crazy. I need to get them replaced for sure.
--- UPDATE ---
I Found a site that suggested if the tire was indeed made before the year 2000, the code is interpreted differently.
So, CLJ-492, was made in the 49th week of the 2nd year of the decade
CLJ-291, was made in the 29th week, of the 1st year of the decade
CUB-073, was made in the 7th week, of the 3rd year of the decade
Regardless, all of the tires are nearly 30 years old. Not bad for getting your money's worth... Ha ha
1954 Chevy 3100
Insomniac
Insomniac
Code is week and year. So CUB073 should be 7th week of 1993. In any case, they are too old.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I've run (and am running) tires that are 40-50 years old. If they haven't been in direct sun their lifespan is infinitely longer. If there is no visible cracking on the surface, that indicates that the rubber is still pliable. We could argue that tire date coding is one of the biggest scams ever perpetrated on the public, but recent events have superseded that milestone. I go on a tire-by-tire basis - expiration dates are absolutely worst-case scenarios. If there's no cracking I would run them out - but then again I don't believe everything the government tells me and I don't have money to spend replacing tires that I have closely inspected and are still safely viable.
1951 Chevy Panel Truck
If you want to be safe about it, they're good for tire swings. Just be sure the branch you tie them to is sturdy enough. wink
MiraclePieCo Agree with your take on tires,Ithink they live best in service. To run 80 on the interstate all day better get some Michelins! To get to the gas station in town run beaters have junkers 60 yrs old ,think the warrenty ran out !! My machinery jocky neighbor said keep em out of the sun !!
It seems impossible to wear out old all weather tread; even while using them for donuts and drifting! cool
Might as well treat your truck to some new ones sooner than never.
'59 Chevy Suburban, NAPCO
One other thing to think about is how much smoother your truck will ride with new tires. Those old ones may well not blow out before the tread is worn off, but I do like the feel of new tires after running stiff and noisy old ones.
Another factor is radial versus bias ply tires.
I've heard that radials rot from the inside out in about seven years, so they should be replaced at least that often regardless of the tred that is left.
Bias tires seem to last forever if you keep them out of the sun.
Case in (extreme) point: The front tires on Lurch are over 80 years old. How can I tell? The size is 30x5, which changed to 5-20 in the mid-1930s. See the pic below and shudder.
For safety (?), Lurch has inner tubes and flaps that are only 4 years old. Also, I only drive at around 20 mph. ;-) I've only had one flat with driving these tires for over 25 years.
Silly? Yes. Stupid? Maybe.
Cheers, Dean
Lurch's right front tire. ;-)
Dean 'Rustoholic' Meltz
Lurch: 1927 1-Ton Chevy Cattle Truck
Old and ugly is beautiful! -- The Saga
Lurch's Gallery
Justin: 1928 Chevrolet AB Canopy Express
Price out a new fender, paint and labor, then price out tires. If the tread lets go, the old hard rubber will beat the fenders to death. Thats how I decided when I bought new ones. Mine had 10,000 miles and 18 years old, but still looked new.
Bond Villain
Bond Villain
Yeah, personally, I dislike replacing tires with usable tread still on them. But I think I would dislike being dead (or causing someone else to be dead) even more.
I made my decision sortta like Joe's a couple of years ago during a ride to the big show at Winchester when I was going down a hill about 60 MPH and it occurred to me that I had owned the truck for nearly 20 years and was still running the tires that were on it at the time ... If one failed ... going down a hill ... 60 mph ...
I have new tires. And the clock is ticking. My goal is to wear the tread off right about the time they date stamp out. smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
In that code how do know what decade?
The paste and copy below is from the Spoon back in '19. I was lucky when I had a blowout on a Michelin LTX 235/85/16 E rated (10 ply) tire that was at about it's midlife point based on mileage and just turned 6. Not mentioned in the original post was the partner tire that also still looked great didn't go 100 miles on a backhoe trailer (it was well within it rated load range) and it blew out. There were no open recalls.
This Public Service Announce is related to tires. A tire story from two days ago that's still very fresh. I was returning home from a (800 mile each way non stop, sorta) trip to check on a pipeline company project I've been roped into, I was in my '95 Dodge Diesel dually about 200 miles west of Dallas Tx on I-20 and had a blowout on the right front tire. Speed was 70 and even though I had one hand securely on the steering wheel (as opposed to finger tips only) the truck immediately shot 10 feet to the right before I could wrestle it back under control, lots of noise and smoke. Had I been on a no shoulder road or had another vehicle been immediately on the right, it'd have been BAD.
The PSA component here is stay aware of and CHECK your tire age. The tire that blew on the front had about 30,000 miles on it and had just turned 6. The manufacture date was 3-13. Cold pressure was 75 psi and no previous repairs, it was Michelin LTX which should be a great tire.
A lot of jurisdictions require tires to be no older than 5 years old when on the front, I've always felt that was a bit ridiculous since I've regularly ran tires much longer with no catastrophic failures. I've gone though several sets of 235/85/16 E rated BF GoodRich Liberator tires and usually at the 7 year mark they go on hay trailers. It's not uncommon for the tread to separate at about the 10 year mark. However due to the way we pull at low speed on secondary roads it's never been a problem. I've never had em blow.
The above said, it's to the tire shop tomorrow for new steer tires and one very good looking Michelin will be set-aside for trailer duty.
RonR
1970 340 Duster
1964 CJ5
Crusing in the Passing Lane
I have run many bias tires way more than 10 years, the recommended interval here, many tire shops quit at 10 years, however, many Michelin’s have failed after many(more than 10) years.
Ed
I've had my truck for 18 years and the tires were on it when I got it. It was a farm truck so not many miles on the tires and they look like new. I suppose should replace them, but I only put a few miles on it myself in a year. Plus I imagine I'd be stuck replacing the wheels also.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Probably shouldn't admit this but I ran the B.F. Goodrich Radials on my 37 for20 years. My truck does stay in the shop and I did look closely at them every time I washed the truck. Still no cracking ect when I took them off this summer. I took the tires to the recycle place so no one would think they were practically new and run them which would have happened if I left them at the tire place!!!
......needless to say, the day before I ran the little blue pickup well past 100 on I-85 then later that night decided I'd be smart for once in my life and had new ones put on two days later! I realize I got lucky this time!!!
A local truck buddy of mine got tired of several in our group making fun of his old, cracked rear mud tires on his all original 1967 Chevy 3/4 ton truck he bought at an estate sale 12 years ago. He ordered 2 new rear mud-grip tires online and finally found a tire shop that would install them on his split rims. The shop owner told him the old tires were manufactured in 1969. They still had tons of tread and he’d never had a flat or any other problems with them. He said the new tires did ride a little smoother.
I also don’t pour milk down the sink when it reaches the expiration date printed on the jug. I use the smell test. Just sayin’.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Spotbiltxo said; "I also don’t pour milk down the sink when it reaches the expiration date printed on the jug. I use the smell test. Just sayin’."
Yep, I do the smell test as well. And I was strongly in the camp that tires should be used till used up......Until the incident described above that could easily have resulted in death or serious injury due to a tire failure on two Michelin LTX tires that had just turned 6 yrs. old. As mentioned the first fail was on the front of the dually, the companion failed on a trailer several weeks later. The tires had zero visual clues they were less than perfect.
It can happen. I do believe old school bias ply tires are much less likely to have age related suprises. Radials, I know it can happen.
Good Luck,
RonR
RonR
1970 340 Duster
1964 CJ5
My boss bought a new 1977 K20 when I was 16., had Firestone directional mud treadI 7.50 - 16 from the factory. I was making a parts run (120 mile r.t,),. L. Front sidewall blew ascoss them hood of oncoming car on narrow, busy 2 lane. A
Gets ones attention.
BC
1960 C60 pasture art
There was an article in Old Cars Weekly back sometime ago where the editor told or a tire exploding in his trunk, or maybe it was someone else's. It had never been on the ground so I suppose, (no not assume) but suppose the hot temps in the trunk did it in. It looked nasty for sure!
Check the sidewalls on the 50-year-old bias-plies on my '34 Ford pickup (below). Solid steering column, metal dash, no bumpers, no seat belts - the adrenaline rush when running 85 mph in rush hour traffic is something money can't buy!
After thinking about how i'm not ready to die yet, and really like the truck in the current shape that it is in. So, I drove (my car) to the tire store and ordered some replacement cooper discoverer tires. Pmetric not the LT series, and will have them installed on June 17th.
Better safe, than dead or sorry.
1954 Chevy 3100
I was a bit skeptical about replacing old tires with good tread considering myself frugal but practical. Then when we had temperature at 115-116 degrees for several days this happened to the spare on my trailer.
The trailer doesn't get used much. I did replace the tires on it and use one of the take-offs as a spare. It had plenty of tread and thought it would be fine as a spare. The trailer sits in the shade at least 1/2
the day and most of the tire is shielded by the trailer in the afternoon. I don't know exactly how old the tire is but it is probably a teenager. Made a believer out of me. Should be attached pictures but not sure I did that right.
Chuck
That is how radial tires usually fail!
Ed
Bond Villain
Bond Villain
Same here- Here's a shot of a radial tire on one of the dump trucks at work, somewhat older, that just blew while the truck was parked in the lot. Naturally, it had to be the inside one ...
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Yes, replace the tires as soon as possible and do not do what I do under any circumstances. Yes, replace them!
This whole conversation really has me on the fence. I put new tires on my 54 3100 in January of 2016. They are bias white walls and cost $900 for the set of 4. I probably have less that 500 miles on them and I don't take it on the interstate. Original driveline and it does not like interstate speeds. I hate the thought of spending $1,000 on 4 new tires when I haven't wore out the ones on it but I get the safety concern with old tires. A lot to think about.
Dave from Northern Kentucky
My 54 3100
Dave, this is just me and I have been accused of being a bit too risk tolerate. After a BAD experience with a blowout on the front of my dually at 70 mph I will not have old radials on our vehicles.
Bias ply tires are a totally different animal. I personally wouldn't be afraid to drive 10 year old (and beyond) quality bias ply tires that look good and have have been out of the sun on secondary roads. Your 5 year old tires would be good to go at my place.
Good Luck,
RonR
RonR
1970 340 Duster
1964 CJ5
52 Carl Nothing like a fresh set of Michelins,aligned and balanced...run a long time !!
