1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I am reconsidering the future of my 2 ton dumptruck. Though the 261 has always carried heavy loads really well I would rather put the low mileage motor into a small truck and put a v8 that it always needed into the dumptruck. I understand a v8 is a direct bolt in? Because of the gearing it should be a motor that likes rpms.
But the tranny has always had this noise. I assume it is the tranny. It is a very loud vibrating noise when the truck drives at freeway speeds with no load on the engine. It does fine either accelerating or decellerating with the tranny but let it coast in gear and the noise comes in. I assume this is bearings? My truck has the dumpbed so I guess it is easier to stick with this tranny? What will it need?
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I had a trans in my 48 that sounded horrible and was leaking gear lube. I ended up pulling the old PTO box off and running it with out it. The PTO ended up being all of the noise and most of the leak. I know you need that PTO to run your dump but I would see if it needs rebuilt before tearing into the trans. Just a thought, Scott | | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | I had a similar vibration/noise with my 2 ton too. It wasn't there all the time just when it was running at certain speeds. The problem turned out to be the hangar bearing, on the drivshaft, just behind the cab. The rubber packing around the case had worn away and the bearing was loose. Fixing that up eliminated the vibration and noise. It was suggested, on here, that Devcon might have a product. I looked them up and found a product that looks perfect for the job.
Geo. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | That sounds like a possibility. I know it doesn't sound like it comes from the rear end. It sounds like it comes from the tranny or it could come from right behind it. The tranny works perfect otherwise.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Tony M: I understand a v8 is a direct bolt in? You need the right bellhousing to fit your frame and the V-8. The 235/261 bellhousing isn't going to do it. I understand the easiest bellhousing is a '63 to '67 or so. I don't know about the engine mounts on a '62.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Hmn. I'm having '2 ton truck envy'.
This is amusing to me because that is kinda how I found the 'Bolt. Back in high school(early to mid 90's) I was thumbing through the local truck trader... '1941 1.5 ton chevy truck - no bed - runs great ..less than $2k' and it had a picture... I was like 'oooh - aaahhh' neat... I didn't go look at it cuz I figured I'd have a hard time keeping it running... but I always remembered it cuz I thought it looked neat.
anyway... later on after I had the internet... one night I decided to look for a picture of a '41 chevy ton truck... and found all kinds of stuff, including the 'Bolt. heh.
-W | | | | | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | you might try looking at some wrecking yards for v8 parts becuse some of those 62 trucks had 283s in them im not shure but some may have had 365 or 409. But by far the easist thing would be to find some parts out of a 62 truck that had a v8 | | |
