9 members (Wickedbass, Gabes-trucks, Ponchogl, Otto Skorzeny, 52Carl, dt235sd, BC59, 2 invisible), 153 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#140550 01/03/2006 3:59 PM
Apprentice
Apprentice
Has anyone added shocks to an AD-vintage 2 ton? I'd like to do this to my 52 6100. Thanks for any info.
Joe Padavano
Joe Padavano
#140551 01/03/2006 7:38 PM
It would be a waste of time and money. There isn't enough bounce in that heavy of a truck for shocks to work and you would never know the difference.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
#140552 01/04/2006 8:22 AM
My 1957 10500 (2-1/2 ton) Fire Truck has factory front shocks...don't know if they really help, but it's neat to talk about!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
#140553 01/04/2006 9:08 AM
About the only places you might feel an improvement is over stutter-bumps and possibly speed bumps,where they might reduce the bouncing (especially the rear) to one or two hops instead of a series of 'em. If you have the shocks and some time to burn up,I'd say go for it! Every little bit helps,and a little help is better than no help. Helpful Hint-it might be good to use shocks that are relatively easy to get and not too expensive,maybe gas (Rancho) shocks for a Chevy one ton 4X4;they should be beefy enough to hold up for a good while,but if they tend to go south often,you won't wanna blow a lot of money on big dollar parts.
Just my opinion...
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#140554 01/08/2006 2:11 AM
I don't have any on the rear of my extra heavy stiff sprung 1 ton, same wheel base as yours.
When I rebuild my truck into a 2 ton I will add shocks.
When empty and on a gravel road you really need them, unless you go really slow....
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
#140555 01/08/2006 2:38 AM
Grigg - don't put too much effort into the shocks, or any money - GM never put shocks on the heavier trucks because they're really non-functional, loaded or not - the springs are so heavy on the 1 tons and up that there's just no chance for shocks to work to 'dampen' sudden movement
#140556 01/08/2006 2:52 AM
They may not have done it back then....
So why do Semi trucks with even stiffer springs have shocks now?
A railroad car will even have shocks, and they are really heavy.
I still think that rear shocks will help on my truck, I'll let you know if they don't.
Grigg
---All pictures---
#140557 01/08/2006 3:17 AM
I don't think I've seen a semi w/ conventional shocks other than on the front - just like your truck should already have - on the back you'll usually find various configurations of air suspension, particularly air cushioned walking beams for use on rough roads
shock absorbers work more to dampen the bounce of the vehicle on the chassis, where on a truck what is needed is something that keeps the wheels on the rough road - shocks won't do it w/ the giant stiff spring packs on heavier trucks
#140558 01/08/2006 4:19 AM
Heck if it bounces....add some weight!
#140559 01/08/2006 5:24 AM
Shocks won't do a bit of good on an unladen heavy duty truck; when you hit a bump the spring rebounds back to the maximum and basically stays there, if it deflects at all. This is also why trucks ride better at near their rated weight, the spings are actually able to work.
#140560 01/08/2006 5:49 AM
Shocks, were indeed, a seldom used option, on Advance Design/New Design G.M. Trucks. Out of all the 2 ton '47-'55 trucks, I've had. Only one of them had Factory Shocks. I've got a 1951 Chevrolet Truck filmstrip, that shows, these shocks.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#140561 01/08/2006 3:21 PM
they didn't put the shocks on rear of spring mounted semis at least thru the early 90's they do put them on airride suspensions on both the tractors and trailers.
#140562 01/08/2006 3:22 PM
if you can figure a way to mount airride suspension that will make more difference
#140563 01/08/2006 4:25 PM
Hello Everyone,Firestone makes an air ride suspension system called "Ride Rite" that looks like it would work.It can be purchased through A W Direct in Connecticut.Check it out @ www.awdirect.com.I was thinking of useing it on my '53 6500 wrecker but never did.My new wrecker has an air ride seat that solved that problem lol.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#140564 01/08/2006 4:43 PM
Chevrolet had optional shocks for the 1.5 ton trucks and were mostly used with a panel trucks that carried light loads; you could get reduced load leaf springs for these vehicles. I have a 1935 1.5 ton stake truck that was bought by the US Forestry Dept and it has 157" wheel base and has overlaod springs in the rear (They were an option) and it has double action optional shocks all the way around. They maybe help a little bit on washboard roads when running light.
34 & 35 trucks are the greatest
#140565 01/08/2006 5:35 PM
I am considering an air only rear suspension for the rear of my 48 2 ton, no springs. But that will be a few years off yet. I'll test all my other modifications out on the new leaves I got last year, then think about air when I run out of other things to do to the truck. I'll be sure to have shocks then. I'll also keep the 16,000 pound GVW.
Grigg
---All pictures---
#140566 01/08/2006 5:49 PM
Just a note on the Firestone air spring kits for trucks.
As far as I know they don't make a full air suspension kit for pickup sized trucks. What they do offer is air helper springs. They allow you to put air in them to carry more weight, or to level your truck with the same weight you normally carry, but they will not improve your empty ride unless you loose some of your original springs and rely on the air springs for the weight capacity.
At http://www.keldermanairride.com/index.php
they offer many different kinds of air suspension kits, some that use air springs to smooth out the ride but retain your leaves, some that replace the leaves all together.
---All pictures---
#140567 01/09/2006 3:06 AM
I have a 46 1.5 Ton, and have been removing one spring at a time to 'soften' the ride just a bit.
As I will NEVER carry a load on the flatbed, I am guessing it will be ok.
I have now taken out 2 in the front and 3 in the rear. (added some spacers to keep deck height) and I can finally start telling some difference. I may take out one more front and one more rear.
I did start noticing it wanting to 'bounce' a little on the highway going about 55 or so.
I was thinking shocks might be the answer AFTER I take out a couple more leafs.
Anyway, a 1.5 ton is not for 'soft rides' anyway, just don't want it breaking my spine hitting a few bumps in the road.
If at first you don't succeed . . .
er . . . then skydiving may NOT be for you!
1946 Chevy 1.5-Ton Flatbed Completed
1946 Chevy 1.5-Ton Just getting started
