8 members (Bill Trotter, Hotrod Lincoln, JoergK., Cosmo, klhansen, Stovebolt48, 1955 1 Series, Bill Hanlon), 117 guests, and 1 robot.
Topics128,195
Posts1,057,373
Members48,469
just bought a 1954 Chevy 3100 with a straight 6cyl. is runs good max speed 38mph, body is decent. looking to clean it up add p/s and increase the speed to 65mph. i want to use the truck here and there. don't want a show truck just a clean good looking updated truck for weekend use.
nice to meet you all
Welcome to the 'bolt, please post some pix of your truck. It must have a pretty steep gear in the rear end to only go 38 mph!
Another quality post.
Real Trucks Rattle
Welcome to the Stovebolt madness. There is no cure! shake
Former Workshop Owner
Lot's of good information here to help you achieve your goals.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
AD Addict & Tinkerer
Welcome to the “Bolt”! Assuming you have the stock rear that came with the truck, stock 3100’s came with a 4.11 rear and is good for at least 50-55 MPH. At that speed they are a bit noisy, but these old Stovebolts can take it! Even at that speed, they are only doing 2400-2700 RPM.
With that said, I have a 4.11 in my ‘52 with a ‘59 235 and I feel your pain. I also plan on either changing the gearing in the rear to 3.55 or installing a T5 tranny with the appropriate rear.
This is a great forum to get you where you want to go with your truck! See you around the garage forum!
Phil
Project Journals
Stovebolt Gallery Forum
thanks, ill try and post some pics... not sure off the rear ratio will check into that
Welcome to Stovebolt. This is THE place to be for us old Chevy and GMC lovers. Ask questions in the garage forums and we'll help you get to where you want to be. Good luck, visit often.
thanks guys... taking a little time learning how to navigate these forums.... your the second person mentioning the "Garage Forums" by that do you mean any of the forums other than the "Welcome" forum????
one other thing how do you post pictures on your profile or even in a post???
The garage is the list of forums they are broke down down to many groups. Click on forums and scroll down you will see the list. Tech tips is a great library as well. See it top right of page. First thing in welcome centre section. First forum list is how to put pictures in your post. Read it first.
FYI, you cannot put photos in your profile. You can, however, put them in any forum except the Greasy Spoon Forum. Instructions are in the left margin of every page unless your on a cell phone.
As you scroll down the list of the different forums the official title is "Shop Area Forums". Why they call them Garage Forums here I have no idea.
Hope that helps. Welcome to the Bolt!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
