2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
Page 2 of 2 1 2
Sorry lost picture
37 Chevy 1.5 ton
17 Dodge Brothers Roadster
23 Dodge Brothers Touring
23 Dodge Brothers Coupe
73 Plymouth Scamp 2 dr
John,
I am talking about the channel lined by cloth that the glass slides in as it goes up and down. The two pieces should go on both sides (for and aft) of the glass from top to bottom, but not over the top when the window is all the way up. I know some people have it go over the top but I don't think it was that way from the factory.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
back yard wrench turner
My fuzzy channel goes over the top on my '38.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
John,
You are correct. That channel is supposed to extend down to contain the soft channel for your glass. Kent is also correct about the original soft channel, however, as a practical matter, a one piece, soft channel from lower front to lower back is an excellent option. I like the channel without the chrome bead. It looks better and is MUCH easier to work with. Mine stuffed in so snug that I did not fasten it in place.
I think I have a pair of NOS running boards for your truck. I will check this afternoon.
I have a 1936 Low Roof 1-1/2 ton...look at it here, if you want. https://vccachat.org/ubbthreads.php...w-roof-semi-lots-of-pics.html#Post216672
I also am about to start a 1938 Suburban project.
Mike Russell
Columbia, MO
1936 1-1/2 Ton (RD) Stake Body Original
Kent, Wayne and Mike, thanks for the input. So how long should the hard channel be? The one in My door is only about 1 1/2” long.
I guess things will make more since when I have all parts in hand.
Been glass shopping. Any suggestions?
Mike, Would be interested in running boards. Pm me
37 Chevy 1.5 ton
[img]https://www.stovebolt.com/ubbthread...C3FE5C8-D6B1-4AEF-AAE4-04D354B4BFED.jpeg[/img]
Shot doors and interior door panels with 2 k primer and hung on truck.
Original stock radiator back in truck and working on sheet metal above radiator.
My truck has 4 metal strips that hold this in place. Wondering if this is a repair or these strips are original?
37 Chevy 1.5 ton
the metal strips are a repair. my top plate is cut short to make room for moving the radiator forward. I have a GMC motor that is longer than the Chevy.
Wayne
1989 Silverado
That top panel should bolt directly to the side pieces. I can get a better look at one tomorrow and maybe send you some pics. I will send pics of the running boards to the email in your profile.The hard channel should go down to where the window rests when it is all the way down. There is a shelf in there that should have a rubber pad on it so the metal bottom glass channel will not squeak or rattle when it rests there.
Mike
As you can see in Wayne's photos, the '38 is a different arrangement that your '37. The '38 has a narrow band over the top of the core and a flat panel to fill between the radiator and the grille. A single, shaped panel does all of this on the '37.
Mike
john duglos In your tranny look at the space between the brass synchronizer ring and the gear,if the 3 are about equal probably OK if to close may want to grind easily when you shift. Look closely at the teeth on the gear where the shift collarengages it these teetth will be hidden when in gear, If the teeth are chipped-up it means they have been ground into gear and are more likely to jump out of gear. hope that helps Also if the shift collars too easily go in gear by hand it means a lot of wear.
Joohn Sorry I rold you all wrong on that gear box. You have a crash box No synchronizers,just look for chipped teeth and so forth.
Gears looked ok. Appreciate the Imput
37 Chevy 1.5 ton
Roughed out top panel for radiator.
Now working on radiator side panels
37 Chevy 1.5 ton
[img]https://www.stovebolt.com/ubbthread...5DF31E4-6746-46C2-A2E0-08B15FB96A5F.jpeg[/img]more metal repair getting done. Aftermarket grill seems to fit
37 Chevy 1.5 ton
Radiator and surrounding sheet metal finally aligned. Thanks for all your help Mike.
Decided to hold on making new chin for radiator support till I have a lower radiator trim piece in hand.
Finished front cab corners.
37 Chevy 1.5 ton
[img]https://www.stovebolt.com/ubbthread...BDF6475-C4AF-49AA-A673-AB50A8875351.jpeg[/img]
Painted underside of cab and backs of panels today.
37 Chevy 1.5 ton
Coming along really nicely, Awesome work man !
Simply put, good work and looking good. Going to be one sweet truck.
Cab is painted. New back window installed.
37 Chevy 1.5 ton
Hooked up ignition wiring today and engine rebuild has spark by turning key. Need to put on a muffler, cooling system and temporary fuel and ready for initial start on engine rebuild
37 Chevy 1.5 ton
Drove truck around farm today sitting on a milk crate and running off boat tank. Engine sounds great. Unfortunately have to put away till next fall. May paint doors and install windows and seals this summer.
37 Chevy 1.5 ton
JRZ Offline
Moderated
Moderated
Hello John my name is John Zimmer I also have the same 37 truck I swapped the 216 for a 235 and I’m having problems with getting the clutch and throughout bearing to work properly I’m wondering if you swapped engines and how did you get the clutch to work properly. I know that the 37 was a single year design so I had to swap bell housing to a later one which changed the clutch fork etc. I just want to pick someone’s brain so I can get this truck on the road. Thanks
Hi John Zimmer, I just found d this post. If you wish pm to discuss clutch iasues..
Finally brought truck back in shop. Haven't touched since ce last spring. Will be working on daily and will post provress
37 Chevy 1.5 ton
Originally Posted by John Dlugos
Hi John Zimmer, I just found this post. If you wish pm to discuss clutch issues..
He'll have to post a couple more times till he's no longer moderated before he can send PM's.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Been working on truck a little every day. Finished backrest on seat yesterday. Started wiring dash
37 Chevy 1.5 ton
Just about done restoring. 13 years. Thanks for all the help and parts to make this happen
Last edited by Gdads51; 09/03/2024 2:41 AM. Reason: Remove image link in text to allow Attachment Manager to display photo
37 Chevy 1.5 ton
Your truck is beautiful!
Wayne
1989 Silverado
Page 2 of 2 1 2
