4 members (32Fordpuchoptop, ‘37ChevyPU, Otto Skorzeny, 2-Ton), 105 guests, and 2 robots.
Topics128,050
Posts1,055,675
1952 Chevy Truck
1952 Chevy Truck
I'm looking for directions or tips for installing interior sun visor brackets.
My kids gave me a pair of interior sun visors for my 1952 Chevy Truck. They came from Classic Parts.
https://www.classicparts.com/1947-53-Inside-Visor-Bracket-Zinc-Right/productinfo/25-012/
Do any of you know how to mount the left and right brackets?
I can't find any instructions on the web or videos on YouTube.
Thank you for your wisdom.
Gerard
1952 Chevy 3100 with GM Straight 6 250 engine
If you can't easily see where they mount you probably have the headliner covering the hole. On each side there should be a large hole in the metal structure surrounded by three small holes for the screws. When I mounted mine I was going thru a fiberglass headliner but knew the approximate location of the mounting surface. I used an ice pick to locate and then open the holes. I don't have a photo of before installing the headliner, perhaps someone can supply that. In the mean time perhaps these photos (if they show up) will give you the approximate location of the underlying metal mounting surface.
[img]https://www.stovebolt.com/ubbthread...d/Number/21243/filename/IMG_3008.JPG.JPG[/img]
[img]https://www.stovebolt.com/ubbthread...d/Number/21244/filename/IMG_3016.JPG.JPG[/img]
That’s a good topic to start Gerard. I didn’t know about this forum four years ago when I bought my ‘57 3200 and installed interior visors. I tried my best to hold them in place and swing them around but I goofed because when I swing them to side window they run down hill a couple of inches. I’ll be interested to here the pros explain this.
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
I bought sun visors from truckshop and got a template in the packaging long gone now should of kept them
Tim,
You know that you should keep everything!
Chris
1952 Chevy Truck
1952 Chevy Truck
Thank you for this. A previous owner cut a hole in the headliner and I can't get the bracket to fit.
I'm guessing they cut the hole in the wrong place.
I may have to remove the entire headliner to find the location you described.
When you mounted your visors, did they fit easily?
1952 Chevy Truck
1952 Chevy Truck
Brad Allen - I'd love to get the PDF. My email address is [email protected]
Thank you,
Gerard
I would say they are a snug fit. You have to be careful with the NOS or originals that you tighten them down equally, if you don’t the ears can break off, trust me on that. I used a sharp punch to locate the three screw holes and for the first hole for the arm, I then enlarged that hole carefully with an X-acto knife. Email is sent, that is quite the spam filter application you have.
Moderated
Moderated
Brad Allen, I would also like to get a copy of that PDF if possible. I am trying to mount visor brackets in a 1950 pickup that has custom interior and headliner. Would like to have the best chance at not screwing it up. Thanks
I would be happy to send it to you if you provide an email? I see you are still being moderated so reply here I guess?
Moderated
Moderated
Bob Kerr, [email protected]. Thanks Brad, I appreciate it.
Brad is it possible you could e-mail the PDF for the sun visors? e-mail is ( [email protected] ) Thank you, Joe Gimer
On it’s way.
WARNING: Don't crank the attaching screws down too tight or you will snap the ears off. Don't ask me how I know...
1951 Chevy Panel Truck
Here’s a pic of my 54 GMC. Not a real good point of reference but the connection is the same on both sides.
Hey Brad, could I get the PDF please? [email protected]
Thx much,
Derek
On it’s way.
Gerard buy a service manuel for your year and keep it by your chair it helps so much . Great for long rainy evenings !!
Moderated
Moderated
Hey Brad, could you send me the PDF as well - [email protected] Thank you!
Canadian54, on it’s way.
Brad can I also get a copy of the PDF?
Drew54
Drew
1954 3104 3 window
I will send it today.
Moderated
Moderated
Is there any way I can get the template for the sun visor installation, my email is [email protected] thanks
Just a reminder that the visor arms are right or left sided. They don't work switched.
DonBolt
1955.1 3100
235, 12v, 5-window, 5 speed
Here's a pic of my 54 3100 if that helps...
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
AD Addict & Tinkerer
Brad is still active on this site, so maybe a PM might get his attention.
Phil
Project Journals
Stovebolt Gallery Forum
Here's the one your looking for ? Think its from Brad, originally. You should be able to download it and print it.
47-53- AD -Right-Visor-Pattern
Ron - - Dusty53
1954 Chevy 3604
Moderated by  ndkid275, Phak1
