6 members (Steelonsteel, dt235sd, Mike Burns, Youngin' Tut 59, Hotrod Lincoln, Hanks custodian), 65 guests, and 2 robots.
Topics128,066
Posts1,055,871
Members48,428
#1386042 11/26/2020 6:06 PM
Hi All,
My 50 Canopy Express has what appears to be an original fuse panel (two clip type) mounted in the upper driver side kick panel area. Weren't these originally mounted in the engine compartment on the firewall?
Does anyone have a pick with the original mounting location? I want to install some kick panel speakers and need to relocate the fuse panel since it's in the way.
Thanks!
LOS ANGELES, CA
48 FLEETLINE AERO, 50 CANOPY EXPRESS
52 SUBURBAN, 57 BIG WINDOW Pickup, 64 Malibu CV
classicchevs #1386045 11/26/2020 6:40 PM
classicchevs #1386055 11/26/2020 6:56 PM
on the fire wall
1950-1951 fuse box/panel
classicchevs #1386111 11/27/2020 1:23 AM
Mine has the the small fuse box on the firewall just like Brads, but also has the the one like tclederman posted on the driver side kick panel.
Did the 1950 series come with the full size fuse box/panel? I don't see holes for it on my firewall. My truck is a Canopy express not sure if they were originally installed in the kick panel area. In any case I need to relocate it to the firewall. Any additional input would be appreciated.
Thank you!
LOS ANGELES, CA
classicchevs #1386120 11/27/2020 2:08 AM
What is in the jar in your picture ,never seen orange windshield washer fluid
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
classicchevs #1386125 11/27/2020 2:55 AM
What intrigued me was the hourmeter(?) toward the center top of the firewall. Shows up in the first picture, but not the second. I have seen orange windshield washer fluid, so that wasn't surprising to me.
classicchevs #1386130 11/27/2020 3:55 AM
The 1947-Mid-49’s should be like this, the 5-fuse panel, wiring harness is different for this purpose, this GMC truck I owned was a low mileage original. They should not have the two OEM, adding the other panel would give you a lot more fused circuits though. This is from the 1948 owners manual, you can see photo and instructions show the 5-fuse box only.
https://www.flickr.com/photos/advance-design_parts_co/50650482883/in/album-72157631872034068/
https://www.flickr.com/photos/advance-design_parts_co/29402434846/in/album-72157631868452754/
https://www.flickr.com/photos/advance-design_parts_co/14200833813/in/album-72157631868452754/
Here you can see the page from the 1950 owners manual, 2-fuse block only.
https://www.flickr.com/photos/advance-design_parts_co/50650503243/in/album-72157631872034068/
The jar was a NOS Windshield Washer accessory (the jars are dated by year). I use orange Rainx fluid because it does not freeze.
https://www.flickr.com/photos/advance-design_parts_co/14039737010/in/album-72157631868452754/
The small black box is a period correct Chevrolet dealer service minder, it rewinds with a small key, they are fairly rare and usually don’t come with a key.
https://www.flickr.com/photos/advance-design_parts_co/8460965541/in/album-72157631867396207/
https://www.flickr.com/photos/advance-design_parts_co/8462063464/in/album-72157631867396207/
Brad Allen #1386131 11/27/2020 4:15 AM
Thanks Brad, That's a cool little gadget. Does it count down somehow?
classicchevs #1386132 11/27/2020 4:19 AM
No they just roll it to the miles interval so the owner can see.
classicchevs #1386134 11/27/2020 4:24 AM
So it's like the stickers they used to put on the door jamb.
