| | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 55 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 55 | Hi All,
My 50 Canopy Express has what appears to be an original fuse panel (two clip type) mounted in the upper driver side kick panel area. Weren't these originally mounted in the engine compartment on the firewall?
Does anyone have a pick with the original mounting location? I want to install some kick panel speakers and need to relocate the fuse panel since it's in the way.
Thanks!
LOS ANGELES, CA
48 FLEETLINE AERO, 50 CANOPY EXPRESS
52 SUBURBAN, 57 BIG WINDOW Pickup, 64 Malibu CV
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jul 2013 Posts: 55 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 55 | Mine has the the small fuse box on the firewall just like Brads, but also has the the one like tclederman posted on the driver side kick panel.
Did the 1950 series come with the full size fuse box/panel? I don't see holes for it on my firewall. My truck is a Canopy express not sure if they were originally installed in the kick panel area. In any case I need to relocate it to the firewall. Any additional input would be appreciated.
Thank you!
LOS ANGELES, CA
| | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | What is in the jar in your picture ,never seen orange windshield washer fluid | | | | | Joined: May 2015 Posts: 11,037 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,037 | What intrigued me was the hourmeter(?) toward the center top of the firewall. Shows up in the first picture, but not the second. I have seen orange windshield washer fluid, so that wasn't surprising to me.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The 1947-Mid-49’s should be like this, the 5-fuse panel, wiring harness is different for this purpose, this GMC truck I owned was a low mileage original. They should not have the two OEM, adding the other panel would give you a lot more fused circuits though. This is from the 1948 owners manual, you can see photo and instructions show the 5-fuse box only. https://www.flickr.com/photos/advance-design_parts_co/50650482883/in/album-72157631872034068/https://www.flickr.com/photos/advance-design_parts_co/29402434846/in/album-72157631868452754/https://www.flickr.com/photos/advance-design_parts_co/14200833813/in/album-72157631868452754/Here you can see the page from the 1950 owners manual, 2-fuse block only. https://www.flickr.com/photos/advance-design_parts_co/50650503243/in/album-72157631872034068/The jar was a NOS Windshield Washer accessory (the jars are dated by year). I use orange Rainx fluid because it does not freeze. https://www.flickr.com/photos/advance-design_parts_co/14039737010/in/album-72157631868452754/The small black box is a period correct Chevrolet dealer service minder, it rewinds with a small key, they are fairly rare and usually don’t come with a key. https://www.flickr.com/photos/advance-design_parts_co/8460965541/in/album-72157631867396207/https://www.flickr.com/photos/advance-design_parts_co/8462063464/in/album-72157631867396207/ | | | | | Joined: May 2015 Posts: 11,037 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,037 | Thanks Brad, That's a cool little gadget. Does it count down somehow?
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | No they just roll it to the miles interval so the owner can see. | | | | | Joined: May 2015 Posts: 11,037 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,037 | So it's like the stickers they used to put on the door jamb.
