7 members (JoergK., BarryP, Hugh63c10, Gdads51, Pre '68 Dave, 2-Ton, 1 invisible),
315
Mod | | | Forums66 Topics128,164 Posts1,057,076 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Saw a friend of mine who knows I am working on a 52panel and at a cruise-in tonight he offered me a 95/96 rearend out of a Blazer. Since it originally was set up with springs I wonder if it would bolt down on my 52 springs, and is the width comparable to the AD? I appreciate any thoughts and experience you guys have had or if anyone has done this. I don't want to pass up a good deal. If it works I can "pass on" some good stuff to other bolters. Lets hear it gang. | | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | Need more info. I believe a 4WD Blazer rear end is "width comparable" to an AD 1/2 ton truck. It is about 4" wider than the 2WD.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
| | | | | Joined: Feb 2000 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 132 | i'll bet you're gonna be changing spring perches but it should be a good fit
i miss obscene phone calls...
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Most anything can be altered, question is, how much. Unless you want to have it cut and shortened make sure it fits within the fender wells. Give yourself at least 1" between the wheel and the frame. And remember measurements are rarely absolute. That's what makes it so much fun... Good luck.
~Jim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thanks guys. I think I'll measure what I have and take the tape measure with me. The guy didn't say if it was a 2wd or 4wd but hey, Maybe someone can use it if I can't. May as well go get it and add it to the pile!! | | | | | Joined: Apr 2003 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 67 | Hi,
when talking about the full frame swap for an AD to an S-10, etc. It has always been said that the S-10 pickup 2wd rear end is too narrow, but the 4wd pickup rear end is just right. So,.. is the 4wd Blazer rear end the same width as the 4wd S-10 rear end ?
(thinking similiar swaps myself)
Royzell | | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | Pretty sure it is. My son got one out of a series 1 4wd blazer and it measures up perfectly for his 51 Suburban. He lucked out and found out it was a posi too after we got it home and ran the numbers on it. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Remeber to measure 300 times before ya cut once Alvin!....lol | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I found that the 2nd and 3rd Generation Camaro diffs were all 62", wheel mounting surface to mounting surface, same as the stock AD. The Z cars also had posi/discs and commonly came in 3.08, 3.42 and occasionally a 3.73. I use the 3.42 from a 2.8L automatic Camaro behind my .72 T5 with a 28.5" tall tire, a 15X7" rim with 4" BS on front and a 15X8 w/4"BS on the rear. Runs 2K at 65-70 in 5th and will drop down to 50-55 without a downshift.
Aside from being cluttered up with a lot of extra brackets that are easily torched off and a 2-5/8 axle tube which is easily shimmed to use 3" u-bolts...they mate up with the S-10 SWB driveshaft and are readily available. Most can be had for between $100-150. which makes them fairly attractive for use with a 235 engine and a T5 transmission.
Just another option that I know fits and works great! I have some pixs in my webshots "shoebox" album of the install. Hope this helps.
Dave | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Like Dave said the Camaro axle is a perfect fit at 62", the same as an AD axle. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | thanks again guys. I like the idea of disc brakes but as it is now I think i'm going to keep the front axle as it was redone very well by the PO. I still have got to actually go check on the blazer axle as I have not been able to catch the guy. I may just drive over there tomorrow and see if it is a 2 or 4WD. I'll let you know! | | | | | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | Yes Royzel, the S-series blazer & s10 P/U rears are the same. As stated though, the 4wd are the wider units. Not related to this list, but worth mentioning, is that the two wheel drive s-10 axles can be used to replace the 4 lug axles in V8 Monzas and Cosworth Vegas to make them accept 5 lug wheels. - mv | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | do a search on rear ends
there is TONS of info on this subject
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | Originally posted by Achipmunk: thanks again guys. I like the idea of disc brakes but as it is now I think i'm going to keep the front axle as it was redone very well by the PO. I still have got to actually go check on the blazer axle as I have not been able to catch the guy. I may just drive over there tomorrow and see if it is a 2 or 4WD. I'll let you know! Lots of Blazers came with rear disc brakes too. Who knows you might even luck out  | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I considered putting in Blazer rear of that vintage in my '42 1/2t PU..I liked the fact that it was 3.42 ratio and had a 6 bolt lug setup. However, it was about 3-4" too wide and the spring perches needed to be cut and re-welded on the otherside of the axle. I ended up using the rear from a '70 Nova which was perfect for my truck. | | | | | Joined: Feb 2000 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 132 | steveg, i think you had a full size blazer rear. no s-10's had 6 bolt wheels...
