0 members (), 115 guests, and 1 robot.
Topics128,078
Posts1,055,938
Members48,430
#137552 03/20/2007 1:43 PM
Junior Member
Junior Member
Anyone have a crank triggered ignition system in their ride?
Kill the rust, save the truck
http://www.rustdepot.com/index.htm
#137553 03/24/2007 4:48 AM
Not in my truck, but in my 89 Cavalier Z24. DIS ignition with "lost spark", triggered by a hall effect sensor in the middle of the block. There is a notched wheel cast into the middle of the crankshaft. Signals the ecm, etc..... I understand some F@#ds had the wheel and sensor on the damper... Makes for easier retrofit to other engines.
#137554 03/24/2007 2:21 PM
Yep
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#137555 03/24/2007 10:41 PM
People have fabbed the 7-slot 6cyl chev wheel, put it on the front ballancer and used the GMECM to manage things. MSD, Eletromotive and a few others make trigger wheels for different aps. What are you contemplating? 8-)
46 Chev One Ton Panel - S10 Frame Project
"What if the Hokey-Pokey is REALLY what it's all about?" - J. Buffet
#137556 04/04/2007 12:34 PM
Junior Member
Junior Member
Thanks for the replies,
I use an electromotive HPV-1 on my Lotus Turbo Esprit, and wondered if any of the stock systems could be adapted for less $$ to other engines.
I really like the idea of losing the distributor, as mine sits underneath the carb float bowls!
Highflyer, I used to have a '59 frog/bugeye sprite. What a great little car!
Lee
