| | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 24 Junior Member | | Junior Member Joined: Feb 2007 Posts: 24 | Anyone have a crank triggered ignition system in their ride? | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Not in my truck, but in my 89 Cavalier Z24. DIS ignition with "lost spark", triggered by a hall effect sensor in the middle of the block. There is a notched wheel cast into the middle of the crankshaft. Signals the ecm, etc..... I understand some F@#ds had the wheel and sensor on the damper... Makes for easier retrofit to other engines.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | | | | | | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | People have fabbed the 7-slot 6cyl chev wheel, put it on the front ballancer and used the GMECM to manage things. MSD, Eletromotive and a few others make trigger wheels for different aps. What are you contemplating? 8-) | | | | | Joined: Feb 2007 Posts: 24 Junior Member | | Junior Member Joined: Feb 2007 Posts: 24 | Thanks for the replies,
I use an electromotive HPV-1 on my Lotus Turbo Esprit, and wondered if any of the stock systems could be adapted for less $$ to other engines.
I really like the idea of losing the distributor, as mine sits underneath the carb float bowls!
Highflyer, I used to have a '59 frog/bugeye sprite. What a great little car!
Lee | | |
