Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Joe H, KEVINSKI, 3B, 1 invisible), 87 guests, and 7 robots.
Topics128,274
Posts1,058,436
Members48,490
#137310 02/27/2007 3:55 AM
:confused: Right now I'm planning on using my '84 S10 Blazer for a frame swap. I know most people use a pickup frame for this swap, but I already have the truck and recently dropped in a 350 and new 350 trans. When I built this Blazer, I swapped the 4wd frame for a 2wd and used a 2wd 700r4 driveshaft to mate to the th350. If I stretch the frame the required 12" or so, should I use a one piece drive shaft? Most S10 LWB p/u's have the 2piece shafts with the bearing in the middle. Does anyone know what if a one piece would be too long?
Scott
"If it ain't broke, I haven't gotten ahold of it yet!"
'51 Chevy 1/2 Ton 5 window
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
One VERY understanding wife
http://community.webshots.com/user/51rustbucket
Toomany2count, thanks. I wasn't sure how long is too long. Your pics of large marge actually the inspiration for cutting up my S10. Before I found your pics I was wandering my yard with tape measure trying to figure which truck I wanted to sacrifice. The S10 track width in the front is perfect to tuck my L78 WWW on 8"rallys, but just needs a stretch & wider rear end. Great documentation and info in your album! Thanks for your help........
Scott
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
other thing is those late model spindles, 98+ will give you dual piston calipers up front
you know your a gearhead when you pick up food to eat at the shop after wrenching all day, and you reasoning for not washing your hands is a little grease makes all food taste better
#137315 02/28/2007 12:42 AM
I appreciate the info, I have to find a U-pullit bone yard around here. I rough measured the S10 with 7" '94 S10 optional rims with 235/75 15 tires and it gave me about 4-5 inches tire to fender. I'm putting chevy 8" rallys with 3 inch backspacing with L78 (roughly 235/75)wide white walls that you can see on my wagon in my webshots. Maybe with such a tall tire I might need the extra clearance for a full lock turn because I want the nose in the weeds. Right now I'm just benchracing until I actually pop the Blazer body off and Mock up the AD.
Thanks again,
Scott
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
Junior Member
Junior Member
For what its worth...my driveshaft came off a late 90's impalla SS, was a perfect fit....
Cool, I was hoping I didn't have to put a 2 piece shaft in there grin
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
Quote
u can use late model(2001 & similar ones) 2wd s10 blazer front spindles(they are a bolt on). these will push ur rims out about 1 to 1 1/2 inches
More info, please? Are you saying that the 2001 and newer S-10s have a wider front track than the older ones?
I'm about to rebuild the front end of my 89 S-10 frame for my AD conversion, and I'd sure like to make the front end wider if needed.
#137319 03/01/2007 12:28 AM
Rule of thumb for GAS engine driveshafts is 60" maximum ctr/ctr of bearing (U-joint or carrier) with a 3" or larger tube of .083 minimum wall thickness. This is for high RPM shafts (gas). Slower speeds can be made longer as can larger diameters but that puts you out of the 1310/1350 series joints in nearly all instances.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
HOLY COW! Dave, you are the drive shaft guru!
Thank you. Maybe you would be able to explain why the factory splits some shafts w/a carrier when they are shorter than 5 ft. What is the advantage?
Thanks again.............
Scott
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
A friend pulled the two piece shaft from his old Chev 3/4 ton truck, went with the long one piece. The thing started vibrating coming down a long grade, front joint came appart and pole vaulted the truck off the highway. He was lucky to survive and the truck was totalled.
Just have this thing built by a quality drive shaft shop, balanced is a must.
1946 1/2-Ton Chevy
51Rustbucket, check out Craigslist.org and go under Detroit for tons of parts. If you find a U-pullit, let me know!
Anyway, the 4x4 S10 rear ends are a bolt in and the old Camaro and standard 10 bolts are all over the place cheap. I picked up a disc brake Camaro rear end last fall for $50. If you are leaving it leaf springs in the rear, Mopar parts has spring pads that weld onto your axle tubes for $8 a pair.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
Thanks Dan, I did finally find a U Pullit yard in taylor. Taylor Auto Salvage 1-734-281-1342 they're at Telegraph and Pardee. There is also another yard right next to them, but it started to rain so I couldn't check that one out. They want $100 for a complete rearend drum or disk.
Oh yeah, craigslist always gets me in trouble, I currently have a couple motors and a transmission for sale on there right now. I usually end up buying something off there instead of getting rid of my stuff.
Scott
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
-db Offline
- Offline
There is another parts place called Parts Galore on 8 Mile Road near Hoover that is pretty cheap from what I'm told.
http://www.soave.com/core/diversified_parts.htm
I appreciate it, I just called their recorded message and they say they have 2000 cars in their inventory on 18 acres.
Sounds like I have to check it out. I just hope it aint too bad of an area, I'd hate to have to buy their parts to replace what was stolen off my truck in their parking lot grin
Scott
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
