1 members (klhansen),
114
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 6 Junior Member | | Junior Member Joined: May 2005 Posts: 6 | Hello fellow stovebolters; I own a 1936 Chevy 1/2tn pickup w/ the 207 motor,(411) ratio and I want to upgrade to highway cruising. I plan on running a 1958 235 cu.in. motor and changing to an open drive rear end. I have a 307 ratio rearend that I plan to install, but am unsure what trans to go with,(compatable w/this rearend) I want to stay with the floor shift(top load) 4 or 5 sp. but need to be sure to have sufficient power for take off in first gear. Any help and advise is greatly appreciated...Thanks...Richard | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have a t-5 from an s 10 truck. i love it. it is a 5 sp./w overdrive. do a search and you will find lots of post on this trans. also go to the tech tips for further info. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | The real beauty of the T-5 especially with a truck like yours and the small cab is that you wont need to fool around with a side linkage shifting trans. Even though you won't really need the overdrive the T-5 is the way to go. You will need to find a later bell housing to go behind the 235. The T-5 is the best thing since sliced bread, as they say. Best of luck | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | My '55 1st Suburban has 3.08 gears in the rear. With the original 4-speed and a GMC 270 it starts out easily in 2nd gear and runs down the highway easily.
I also have 3.08 gears in another car with a V-8 and 4-speed with a 30% overdrive. Its fun to run at 70 mph at about 2000 rpm.
An interesting difference between the two is that I never stall the 270 starting it out. When I switch to the V-8 powered one it always takes me a while to adjust and spin the motor fast enough to start it out in first with out stalling it.
While your long-stroke 235 should tolerate it better than my V-8, it is possible to choose gears that make starting out a bigger challenge.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2006 Posts: 184 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 184 | I've been told that the original 4 spd. non-syncro works fine with re-geared rear ends, but I still have the 'granny' gear in mine. I haven't decided if I want highway speeds or not yet. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Your bellhousing from the 207 may bolt up to the 235. if not a 37- 46ish chevy bellhousing should prolly work with the least amount of modification. The art deco trucks all had the brake and clutch pedals mounted on the bellhousing. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | consider a 250 CI motor for a better oiling system. do a search on the 235 250 and T5 conversion as there is lots of info on this site.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You can also use a Saginaw 4 speed, look for the 2 or 3 groove input shaft, they have a nice broad ratio and matched with the 3.07 rearend are nice for a 235.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I run a 270 with a 3.08 axle in my '57 GMC;my engine is a little worn out though,and that coupled with LT235/85R-16's means it doesn't take too much of a grade to slow it down from my 70 mph @ 2,300 rpm.(It has a knock at anything over 2,500,so 2,300's cruise redline for it.) Speed | | | | | Joined: May 2005 Posts: 6 Junior Member | | Junior Member Joined: May 2005 Posts: 6 | Thanks for all the information Guys, we have a pull-ur-part here that has 4 and 5 speeds for $150.00, I'll go check it out and see what I can find. Thanks again...oldred36 | | | | | Joined: Nov 2006 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 60 | I USED A MUNCIE WIDE RATIO 4SPD IN MINE AND IT WORKED JUST FINE. BOLTED UP GOOD TO THE STOCK GM BELL HOUSING TOO. GOOD LUCK. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Richard, Do you know the horse-power rating for your 207? Also, is there any chance you could mail me photos of both sides of the engine and a picture of the top of the engine with the valve cover removed? Information about the early stovebolt engines does not show up very often. Thank you, Tim lederman@siena.edu | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just thought I'd throw this out.....if you are considering a 5 SPEED, and are planning on running a 28-29" rear tire you'd better STAY AWAY from a 3.08. I went with a pricey IROC-Z 3.08 posi/disc with a .72 T5 OD, 29" tire behind my decent running 235 and it was a BUMMER. It worked okay as a 4 speed but in OD, the rpm's nosedived so dramatically, that I dropped completely out of the 235's power band. I switched to a 3.42 R&P which lets me cruise in 5th gear @ 2000 rpm's at 65-70 mph and can drop down to 50-55 mph without downshifting. If I lived in an area with hills, I'd even consider a 3.73.
I now have a expensive 3.08 doorstop and BTW...I drive my truck every day! Hope this helps you avoid a costly mistake.
Dave | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I agree with Dave. Unless the majority of the driving will be on the freeway. For getting around town you would definately be happier with a lower gear rear. I have 3:90 with a granny 4sp and an O.D. It's a combo that gives me the best of both worlds. | | |
