2 members (pdlightning, Tronman), 104 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
Hi,
I purchased a 1958 Apache 3100 (big window) last summer. It was a frame-off restoration and is loads of fun. Unfortunately, it does not have its data plate that shows colors ect. or fender/hood emblems. I’ve purchased a blank data plate however can’t seem to locate a photo of an original so that I can stamp my truck’s info on the blank one. For example, is color red, ruby red or the code for red? A clear photo of an original would be incredibly helpful. Also, I have the body emblems but the holes are not on the hood or fenders ... does someone sell templates so that I can drill the correct holes to install the emblems?
Any and all assistance is greatly appreciated!
Doug
1950 Chevrolet 3100 (5 window deluxe)
1968 Pontiac Firebird
1972 Oldsmobile Cutlass Supreme
Komoka, welcome to the Stovebolt.
For technical questions please post them in the Garage Forums for the best results. Not everyone stops in here at the welcome centre when visiting......Example: your specific question would go well in the Paint and Body forum or perhaps General Truck.
I'll leave this post here though so members who stop in can say hello and get to know you.
Sorry, Stovebolt.com cannot help you with replacing your VIN plate. Such process is illegal w/o approval of your States licensing authority.
Sir Searchalot
Sir Searchalot
1. Find out what your local DMV advises.
2. What VIN does your title have?
4. Long bed or short, fleetside or step? I realize 3100 is short. Just want to be sure.
5. Your frame is stamped with the partial VIN, If that matches the Title, you are in better shape.
6. All the hood and fenders have holes. Look on the inside and try to see where they were either filled with bondo or plug welded.
If you are like 50% of the new guys, we will never hear from you again. Hope we do. Hope you answer the questions.
Welcome to the 'bolt. Please post some pix of your vehicle.
Another quality post.
Real Trucks Rattle
Thanks for the warm welcome and recommendation
I’m not trying to replace my VIN plate ... I’m referring to the GVW data plate which only lists the color, trim and wheelbase.
As requested
I don’t see any plugged holes as I believe that the hood and fenders may be reproductions
Sir Searchalot
Sir Searchalot
and the other questions?
Komoka, look for the essembly manual for your truck. It may have a page for emblem placement. Many of the vendors sell the manuals and you are likely to use it often. Worth the 30.00.
~ HB
1962 Chevrolet C10
1962 Suburban
Thanks Hambone ... I have the assembly manual however perhaps I missed a reference to emblem placement
Sir Searchalot
Sir Searchalot
OK, no problem. Either we misinterpreted or you edited.
There is one red for 58, "714A" Cardinal Red. Seems you don't know if that red on your truck is original color or not.
The trim is usually left blank
If you have a short wheel base, it's "114"
Stamp the info in the middle of the space or near.
The Assembly Manual does not have the series designation emblem or the hood emblem hole locations. Fenders/hoods were pre stamped with the holes. You will have to find a 58 and measure the emblem locations. Or find someone selling a 58 fender/hood and measure.
Thanks Bartamos
R Online: Content
That is a beautiful truck!!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Much appreciated Rich
