0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#136192 11/28/2006 4:46 AM
Does anyone know how to get the center line of the front axle on a 1959 Chevy truck if it doesn't have a solid axle in it. I'm starting with a stock bare frame and am installing a Scott's IFS.
#136193 11/28/2006 4:56 AM
My guess is, you'll have to set the cab and front clip back on the frame and put the wheels where you want them. A lot of people move the wheels ahead some to "correct" the look in the wheel well area,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#136194 11/28/2006 5:51 AM
I don't know about the TF trucks, but on AD trucks the Assembly Manual has some good diagrams with measurements that would locate the original axle centerline.
I'm sure you can buy a TF Assembly Manual from one of the vendors and get those measurements.
#136195 11/28/2006 5:52 AM
For a 3100 the axle center line is 15.75 inches in front of the dash. The dash is 43.24 inches from the front end of the frame. Therefore the center line of the axle is 27.49 inches from the end of the frame. Another reference is from the center line of the cross member and spring hanger for the front of the rear leaf spring. This dimension is 71.97 to the front of dash, plus 15.75 to the axle center line. This is 87.72 inches from the cross member center line to the axle center line. And anothr reference is from the bell housing cross member at the center line of the rear motor mount holes. This is 7.57 behind the front of the dash plus 15.75 in front of the dash to the axle, this is 23.32 inches.
These are the dims from the assembly manual, but as 48BT said, most will use the sheet metal to locate the front and rear wheels when making these modifications.
I hope this helps.
#136196 11/28/2006 7:36 PM
Thanks for all of the input. This info given will help. I did see on Heidt's install in a magazine that the centerline is 20-7/8" from the front shackle bolt (CL).
