| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 8 New Guy | | New Guy Joined: Oct 2002 Posts: 8 | Does anyone know how to get the center line of the front axle on a 1959 Chevy truck if it doesn't have a solid axle in it. I'm starting with a stock bare frame and am installing a Scott's IFS. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | My guess is, you'll have to set the cab and front clip back on the frame and put the wheels where you want them. A lot of people move the wheels ahead some to "correct" the look in the wheel well area, Scott | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I don't know about the TF trucks, but on AD trucks the Assembly Manual has some good diagrams with measurements that would locate the original axle centerline.
I'm sure you can buy a TF Assembly Manual from one of the vendors and get those measurements.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | For a 3100 the axle center line is 15.75 inches in front of the dash. The dash is 43.24 inches from the front end of the frame. Therefore the center line of the axle is 27.49 inches from the end of the frame. Another reference is from the center line of the cross member and spring hanger for the front of the rear leaf spring. This dimension is 71.97 to the front of dash, plus 15.75 to the axle center line. This is 87.72 inches from the cross member center line to the axle center line. And anothr reference is from the bell housing cross member at the center line of the rear motor mount holes. This is 7.57 behind the front of the dash plus 15.75 in front of the dash to the axle, this is 23.32 inches.
These are the dims from the assembly manual, but as 48BT said, most will use the sheet metal to locate the front and rear wheels when making these modifications.
I hope this helps. | | | | | Joined: Oct 2002 Posts: 8 New Guy | | New Guy Joined: Oct 2002 Posts: 8 | Thanks for all of the input. This info given will help. I did see on Heidt's install in a magazine that the centerline is 20-7/8" from the front shackle bolt (CL). | | |
