Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (tclederman, ranchojuan, greenie-reddy, 1 invisible), 178 guests, and 6 robots.
Topics128,289
Posts1,058,583
Members48,492
Page 171 of 177 1 2 … 169 170 171 172 173 … 176 177
replaced the starter solenoid today. would start fine cold but starter would really drag when engine was hot. seemed to fix the problem.
1949 Chevy 4400 216
Adjusted the idle RPM on the newly installed rebuilt Carter YF. It runs slower now and still starts up easily and stays running without any choke. I’m happy!
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
This nasty virus we are all alerted to, is keeping me down on the farm in the Texas Hill Country where there is no virus (0nly 8 cases in the Blanco area) at least none on my farm. I wish I had hauled my 51 down here with me; getting lonesome now with nothing to tinker with.
~Jim
Continued with my 292 rebuild... Crank, rods/pistons, and new cam installed. still waiting on a few parts (new rockers, HEI, in deciding on intake/exhaust) then will be ready to fire up!
Manufactured a long battery pan on my 54 3100, put two heavy six volt deep charge batteries in series. this way all my six volt lights and gauges including generator and starter. This way I can put under dash a/c in. It is Florida after all.
Tore a 65? C60? Apart yesterday while sun still shining . Salvaged a few parts.Pat66
Im just finishing up my AC install. Keep your eyes peeled on my project journal. I will be posting up pics of the process. Its coming along nicely. Made all the hoses lastnite. Today will be wire time and then vac it down and charge it.
Got a new windscreen cab feels twice as big old one had a lot of white creeping up
Moderator
Moderator
2 Offline
Charged the battery up on the Flag Pole. Started the 637 up, Raised the ladder and ran it for about a half hour.
Clutch will not disengage, so I think it is the the old hydraulic clutch system.
A Forged In Fire champion will be stopping by tomorrow. Trading me a damascus knife for an anvil.
https://kniferights.org/ultimatesteelprize/ethan-lee-2019/
Guess I need to get the camera out!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Socket Breaker
Socket Breaker
1965 C10 stepside.
oil/filter change
lube job on the front end grease fittings
new air filter, it needed a new one too, the old one was filthy. oops.
put gas in it on the way home after a short cruise.
old trucks are fun.
-Woog
After nearly four years of sitting intermittently starting and not starting, running and not running, I finally got my '51 Chevy pickup, the Blue Funk, back on the road.
All it required was endless tinkering and testing and more tinkering and testing and now it starts easily and cruises at 40mph without problem.
Hallejuah!
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
More pix on Photobucket
Got the top end of my motor installed on the stand, got things masked off and everything painted top to bottom on the motor.
Finally wired up the right headlight and parklamp. Just have to install the Distributor, run a wire for it, install the Oil Pressure gauge, wrap up loose wires, install the seats with a new cover, install a sterio and speakers...then I'm done....for now
Barnfind49, keep me in the loop. I see I left out the part that all 6 volt original items work. This way I can hook a/c to 12 volt. Are you installing the thin full length under dash vents?
Just finished the AC install today. Ohhhh how nice its gonna be to not melt away this summer! Now I will actually look forward to driving the truck even on the hottest of days.
Doc, check my project journal for the entire AC write up I just did!
I finally got the first leaf spring bushing out!
Another quality post.
Real Trucks Rattle
Headliner and inside drivers side sun visor installed! What a job
Moderated
Moderated
Just picked up my 51 3100 this past weekend. Came with a parts truck. Today, I took the donor truck wheels and ordered new tires to go on them and then on the 51. Baby steps towards getting it on the road safely. Went with a set of ironman 225/75/15s.
Is this your first AD truck?
Weird to see the name Horvath reappear here. Alan Horvath had an extensive web site documenting all aspects of his AD truck restoration. I referred to it frequently, but he finally passed away and his web site is no longer available. Here's a sample pic from it below. Are you related?
1951 Chevy Panel Truck
Just put a new Thrush Turbo 17711 muffler on the Catfish. I didn't know this thing could be so quiet. So, mellow! I do like it.
And, I finally put a rear bumper on it. Found a pair of original GM bumpers in Paris, TEXAS, for a song.
1955 Chevy (1st Series) 3600
Started on working on the back half of the 64 GMC.
It will get all new wood, already done is new leaf spring bushings and shackle bushings, u joints and center driveshaft support bearing.
Decided to remove the small back window and fabbing up a panoramic rear window now.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Just had a few free minutes... got the passenger side interior sunvisor installed
Pulled my custom transmission crossmember out that I made when I swapped in the overdrive trans. I knew it had some flex in it and it needed gussets on the trans tab. I doubled up the ends where it mounts and then i made some 3/16 gussets and welded them onto the tab. Zero flex now and I’m 99% sure I solved my occasional 3rd gear pop out issue. I drove it tonight up bumpy hills in 3rd and it stayed in 100%. That makes me happy. I will definitely know if I drive it into work tommorow.
Hey, I just finished the same "job" with really bad results using a CHevy Classic Parts 21-457. Way too many gaps. If you get a chance, please take a look at my post in the interiors forum. If yours turned out that well, I'd like to know where you got your headliner from . Thanks! Appreciate your time.
Ron - - Dusty53
1954 Chevy 3604
I set the engine back into the frame!
Real Trucks Rattle
Replaced the starter solenoid on my ‘56. That starter is twice as heavy laying on a creeper than what they are standing under a lift!!
But it's harder to drop it on your toe.
Originally Posted by Patrick M
Hi All,
I took just about everything I could out of the cab of my new to me 1946 Pickup project. I plan on making the cab look nice and leaving the history alone on the outside for now.
Patrick M.
Sounds exactly like what I did with mine, Patrick. The problem is finding a good stopping place on disassembling things and being at peace with reassembling. There’s always one more screw to remove! You’ll have to suppress those thoughts about having come this far... 😊
Let me know if you hit any snags; I took lots of photos.
Good luck,
Greg
Finished! Although never really finished. 2012-2020. Great forum here!
1951 Chevy 3100
I got lots of consternation. I bent a bracket and did not realize it until now... grrrr.
Real Trucks Rattle
Upgraded the electric wipers to delay by installing the optional switch.
Nice
58 Apache 32
Placed a 2021 registration sticker on the license plate of my ‘56... 😊
I fired it up for the first time after the refresh.
Real Trucks Rattle
Rusty Rod, Is that not the sweetest sound when it starts and runs. Replacing my valve cover gasket with a newer version after setting valves. Ed
I got the last screws out of the interior panels on my '37 truck and removed the interior. I can't tell you how much I hate mice. Seriously, I know a lot of creative words, but I can't think of anything vile enough to describe the little buggers.
1935 QD 1.5 ton stake bed
1937 SD 1.5 ton stake bed
1944 MS 1.5 ton stake bed
1946 PW 2 ton stake bed
Put new set of tires on the 37......2 of them slick as a peeled onion!!!
I put in a new headliner, finished wiring the taillights, replaced the oil pressure gauge, wrapped the harness with cloth looking tape, finished all the wiring in the engine bay and cab (except for the stereo), installed weatherstripping in one door... and I made my own lunch.
I got my new door panels put on. Wasn't exactly what I was originally planning on doing but they turned out fine.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Dropped the engine (292) back in after a complete teardown, machining, and rebuild. Waiting on an HEI, intake, exhaust manifolds before starting her up for the first time... Fingers crossed it all goes well...
