0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I know I have seen the explanation as to checking and correcting the accuracy of your speedometer. With the new T-5 transmission, I just want to be sure I'm on the money. My T-5 has a mechanical speedometer hook up and at this point I have hooked my speedometer cable to the T-5. According to the speedometer, I seem to going faster than I really am, which may not be all that bad but, can someone give me the info on checking the speedometer and just what to do to get it accurate. Thanks! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Just check what the odometer reads between mile markers. This will tell you what percentage off the drive gear is and you can install a new drive gear that is close to that percentage from the one presently in the transmission. | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Here is what I did using the street, an rpm gauge and an rpm calculator....
First make sure the odometer is right on the mile and get an odometer gear adapter that goes on the outside of the xmission speedo cable outlet, if necessary. Then rotate the arm inside the speedo gauge where the needle coil-spring attaches until the speed matches a given rpm. Use a rpm calculator online. This can be tricky and take several tries as the very slightest rotation has quiet an effect on the reading.
I set the sweetspot to be accurate around 40-70 mph, as the speedo needle is not 100% across it's entire range.
If you don't want to putz around, just bring it to a speedo adjustment shop. | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | 6cyl, Do you know where you got the speed cable, and which vehicle it came from? I pulled one of an S10, and the tranny end had the correct fitting but the speedo end used a collar/retainer instead of screwing directly onto the speedometer. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | tlorber - Believe it or not, it's the one that was on the truck. It was pretty long and loose so I tugged on it a little bit and it stretched far enough to reach the T-5. I looked at the plastic gear in the T-5 and the end of the cable and they looked the same so I screwed it on. It works fine and it may be accurate. I've just got to find a stretch of the interstate with some mile markers and check it out. My guess would be that you could buy a new one for not a whole lot of money at a NAPPA or good auto parts store. I wouldn't think they would be real expensive, but I might be wrong. Wish I could be more help! Good luck! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Joe it should take you one min. to go 1 mile at 60mph. I think I 30 has the mile markers. Tom | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | just have someone ride next to you on a lonely highway and they can shout the speed at which they are traveling, then compare that to your speedometer. Then, if you are industrious, you can take a pic of your speedo assembly, put it in photoshop and change the numbers to match the new data. Print it out then glue it over the existing numbers. This is a constant problem for car buffs though. What needs to be invented is an unit that plugs in between the speedo cable and the speedo that has a variable adjustment mechanism which corrects for errors. Then you wouldn't have to play the guessing game every time you change the drivetrain variables.
delete my account and pictures
| | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Joe, I got a new cable kit at Auto Zone for about, or less than, 10 bucks. Most do not have the housing with cable already in it. My kit has a new cable that you cut to length. Instructions included. | | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | The T5 transmission has a factory installed offset adaptor that screws into the transmission and the cable screws into that. If you put your cable directly into the tranny your speedo will be way-off. (high)
A company in Milwaukee "Speedo solutions" (414) 463-6660 might be able to help you get the correct gear sets to calibrate your speedo. Have your OD ratio number, and tire/wheel diameter and ring/pinion ratio available. The local Chevy dealership doesn't even have a picture of the T5 adaptor so if you didn't get one you might have to go back to a j-yard and do some looking. I have a picture of the adaptor on page 10 of my webshots "shoebox. Hope this helps. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | This is the first I have heard of an adapter. I know you might need something like that on an electric speedometer set up on a T-5, but not on a regular set up. Why would they use that when they could have put the correct gear in the back of the transmission? I guess I don't understand. :confused: Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Mine had one on it. If i plug straight into the tranny my speedo shows way higher than I'm actually travelling. If I use the adapter it reads a little lower than I'm going. | | | | | Joined: Jan 2005 Posts: 164 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 164 | just have someone ride next to you on a lonely highway and they can shout the speed at which they are traveling, then compare that to your speedometer. Or use your cell phones. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | G.M. used these adapters on practically all there trucks with manual trans. They fine tune the speedo with these. I keep a bunch of them around & check the odometer with the freeway mile markers. I find one that is close to the amount of change needed. If it is the opposite of what I want I take the gears out & switch them. You can pick them up at the pull it yourself lots. The checkout guys don,t know what they are & don,t hardly charge much for them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Any idea if there is a reference for these things anywhere? It would be nice if we could find some GM part numbers for various adapters and their ratios...maybe we could change this from a "stick one on and try it" deal to a "look up the right one on the chart and install it" deal. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | As I mentioned earlier....they don't even show up on the GM dealers parts screens. No numbers....no charts.....but once again, "Speedo Solutions" (414) 463-6660 may be helpful in getting it right the FIRST time. Be sure to have your OD ratio, R&P ratio, and tire diameter available. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Both of the t-5 transmissions i bought have the gear reduction box.One is rectangle and the other is a oblong round shape.I need to check the speedometer and look into getting the right gear for the reduction box.It would be helpful if we all could list our trucks specs and what gear we used in the reduction box.I like texmos idea !!!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | The one that came on my T-5 has a GM logo on it and has the following numbers: 663AJ6 and then under that is .7333AAC
I am running a 230 with a T-5 behind it that has a .72 overdrive and a 3.73 rear end. With this thing installed my speedo reads about 10 mph slow at 65 mph (checked against a GPS). | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Had an oportunity to get out on Interstate 20 today and readily found mile markers to check my speed-distance. I made it between the mile markers with 1.2 miles rolling up on the odometer. I guess that translates to meaning that my speedometer is runing about 20% fast. While checking the odometer reading, my speedometer was reading 80 miles per hour. I figure I was actually running about 65 miles per hour, but I'm only guessing. I'm not really sure what all this means as far as obtaining an adapter, except to report these statistics to an speedometer shop in order to buy an adapter. Is my assumption correct? Thanks, Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I need some comments I can go with, please? Thanks, Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Go ten miles for more accuracy. 20% jives with your speed guesstimate. 80/1.2 = 67 mph | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | You need to slow the speedo down.Count the teeth on the speedo gear at the trans.You will need one with more teeth.One tooth is about equal to two miles per hour.As for the speedo adapters that were spoken about above,they were made by Stewart Warner for GM(and others)to bring the speedo's in the ball park.Hope this helps.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Oct 2006 Posts: 22 Junior Member | | Junior Member Joined: Oct 2006 Posts: 22 | look up united speedometer for the address and phone number. find a place that has mile markers (any Interstate Highway or Sppedometer check point)write down your odometer, miles and tenths drive 5 miles write down odometer reading each mile. call united tell them they will sell you a ratio adaptor that goes between the trans and cable...easier then changing the gear | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | gtow69 has the right idea and probably the cheapest solution. I just fixed mine the same way. The gear you need is called the "Speedo driven gear" and is available at The Gear Box. www.thegearbox.org A 2-tooth change on my gear changed my reading 10mph. | | | | | Joined: Nov 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 54 | I was just browsing the archives over the weekend and reading a thread on a "T-5 rebuild manual" which detailed three different "speedometer" gears to be used, depending on the appropriate rear end of the vehicle. See this link for details. http://www.fordmuscle.com/archives/2002/09/transmissions/LD05-0510-0199.pdf Dave | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Yeah, DW, that's correct. There are 3 different gears (drive gears) that are used. These are on the inside of the tranny. The "driven" gear is the easy one. There are 8 or 10 different gears here. The driven gear and it's housing, is what the speedo cable connects to. Takes 5 min. to change out. | | |
