1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#135370 09/13/2006 4:24 AM
My '56 has a 350 engine with Edelbrock carb. I need to put a kit in it but don't know how to ID the carb. Can't find a tag. Do I need to know what it is or are the kits all the same?
If I do need to ID it where do I look?
#135371 09/14/2006 2:25 AM
I don't know how to ID an Edelbrock, but I'll give you my "this is what I would do" advice. I would get an old Quadrajet from a 350ci GM and rekit it. Quad's have their number stamped on the side so you can get a kit everytime it needs it. I'm just a little partial to the Quad since they adjust and rebuild so easy.
Nice meeting you last week-end too!
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#135372 09/14/2006 10:49 AM
The number should be stamped in the base flange on the front of the carb.
#135373 09/15/2006 2:47 AM
Thanks chuckthetruck. I had tried to ID it by that number on google but it turned up nothing. I finally figured out just use the first 4 digits.
Scott, thanks for the suggestion. I have a Q-jet from my '83 Jimmy I forgot to take back for my core deposit in time. After seeing the price of an Edelbrock kit, I'm considering it. I don't suppose you know if it needs an adapter to fit an Edelbrock manifold, do you?
#135374 09/15/2006 3:28 AM
Cletis, If you rebuild the Q-jet you might want to pick up the book Carbking recommended "How to Rebuild and Modify Rochester Quadrajet Carburetors" by Cliff Ruggles. Excellent book the guy really knows what he is talking about. The book will tell you how to setup the Jimmy carb for your 56.
Larry
I don't own a vehicle that isn't old enough to drink.
#135375 09/15/2006 11:01 PM
Riding in the Passing Lane
The Edelbrock carb is basically a Carter AFB. They are easy to rebuild & drive real good. The gas mileage is not as good as the Q-jet.
1972 Chevy c10 Cheyenne Super
#135376 09/15/2006 11:33 PM
Carburetion specialist
Quote
Will Carter would not like to read the above.
Jon.
The Carburetor Shop
#135377 11/09/2006 3:36 PM
Junior Member
Junior Member
INSTALLING A QUARAJUNK ON YOUR ELDEBROCK MANIFOLD WILL REQUIRE AN ADAPTER. (GREATLY KNOWN FOR ADDITIONAL VACUUM LEAKS)SECONDLY THE Q-JET IS CONSIDERABLY MORE COMPLICATED TO REBUILD AND TUNE. PRICE OF ADAPTER + Q-JET KIT COMPARED TO EDELBROCK CARB KIT????
#135378 11/09/2006 5:03 PM
I think the Quadrajets are a pretty good carb. The thing that screws them up the most is that the shafts wear into the housings and the housings need to be rebushed with a kit. Without it they are mostlikely be a poor performer and have dead spots through the rpm range. If you can't tune a Carter AFB, you might not be able to tune an Edelbrock. Bolting them on is not tuning.
#135379 11/09/2006 11:31 PM
Cletis,
Should be a 4 digit number on the left front flange right where it bolts to the manifold. My 600 cfm says 1479. I have a list of the Edelbrock numbers.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#135380 11/10/2006 3:48 AM
Q-jets also wear out the secondary metering jets.These are not replacable so if they are oblong the carb is junk.Also look for worn metering rods.This carb is very tuneable and can be mounted to Edelbrock intake.I have a Perfomer and it is a direct bolt on.Good Luck
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
#135381 11/10/2006 6:26 AM
Thanks for all the repies. I rebuilt and rejetted my Edelbrock 1406. It runs great. Here's the post about it.
