5 members (2-Ton, rfs56trk, J Lucas, Pete O, Barry Martak), 84 guests, and 2 robots.
Topics128,094
Posts1,056,489
Members48,444
#134432 06/01/2006 6:12 PM
Junior Member
Junior Member
Heading out to the machine shop tonight to pick up my blower ready 383. Called about the total today, all I have to say is eek ! So who else is in the same boat?
'58 Apache: Camaro sub, 383 w/forced induction, 700R4 trans, 4-link w/floating 9" and un-altered sheetmetal.
#134433 06/01/2006 9:21 PM
Rebuilding ain't cheap, especially if you have the machine shop pick the parts, do the assembly and buy the parts. Rebuilding a less common engine can get very costly. I imagine if you had stronger rods, pistons, rockers, etc... plus extensive head work like porting, polishing, putting the heads on a flow bench, for a blower ready motor it would get really expensive!
You can save some money by having the machine shop do just the machine work using parts you supply (pistons, rod bolts n' nuts, cam bearings, soft plugs, valves/guides/ seats)
#134434 06/01/2006 10:18 PM
The cheapest h\p. today is nitrous. Don't subscribe to the whole idea but it is cheap hp.
#134435 06/02/2006 2:09 AM
Seems that everyone is making crate motors today in just about any size, horsepower, and tourqe rating imaginable. in my opinion its the way to go for planting a motor in anything...not to mention the warranty!!!!! Check it out!!!!!!
#134436 06/02/2006 2:40 AM
I saw a guy at the Fallbrook Car Show who has high HP engines, computer controlled fuel injection... 5 wires to hook it up.. they sound great too.. he had them in 59 and 60 station wagons.
Another quality post.
Real Trucks Rattle
#134437 06/02/2006 6:32 PM
Junior Member
Junior Member
Comparing the price I paid for the motor and the parts that are in it I still came out ahead, even after the machining and new pistons. One thing I did learn is to check both banks of cylinders for problems not just one.
The story: Engine sat for a few years with 2000 mi on rebuild with all performace parts. Pull cylinder head...yep everything looks good I can even see the honing marks, the other side must be the same, I'll take it. Few months later...ok time to get this bad boy ready pull other head..hmm chunks missing from that piston, take it to the machine shop. Teardown...hey the ring lands on 4 of your pistons are partially missing and 3 are burnt pretty bad. Shell out $$ for new parts and machine work.
Oh well, live and learn.
#134438 06/05/2006 2:47 AM
Lots of forced induction engines suffer from detonation. My advice to you is to incorporate some type of alky injection. Lots of us turbo regal guys use either a homemade alky kit or a progressive alky kit. Lots of us running 21 plus psi of boost on pump fuel. Go to turbobuick.com and we have an alky injection forum on our board.
Admin for Turbobuick.com
87 GN, and new toy: 1955 Chevy 3200 pickup, soon to have: 383, Cola crank, Childs/Albert 6 inch rods, Brownfield heads, 10:1 KB hypers, CompCam 284 Extreme Energy, Tilton Plate transmission realignment and built Turbo400.
