4 members (rfs56trk, FAST55, delwrench, RaNfLaS), 214 guests, and 4 robots.
Topics128,086
Posts1,056,101
Members48,434
#134157 04/09/2006 9:55 AM
Junior Member
Junior Member
I just bought a 1952 5 window and looking for someone with experience in putting entire a/c unit in or have any suggestions??
My grandpa always said, "Pull up a stump and set a spell". He knew what was best.
Our \'51 5-window Chevy
#134158 04/09/2006 8:09 PM
I don't have A/C experience but if your 283 has it's original heads on it, mounting brackets may prove difficult since they won't be drilled in the several locations for the compressor. You may have to put different heads on,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#134159 04/09/2006 8:33 PM
Junior Member
Junior Member
I don't know if the truck has the original heads, but I will be back in the states soon to find out!!
#134160 04/11/2006 11:44 PM
The thought the early a/c compressors used a bracket that bolted to the exhaust manifold with 2 bolts.The adjustment bracket then bolted to a water pump stud ?
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
#134161 04/12/2006 12:54 AM
#134162 04/13/2006 1:27 AM
I have a 64 belair with factory a/c still intact(on a 283). Compressor mounts on right side. It is about 25 miles from here, but i will be there this weekend. May try to take a look if wasps don't change my mind.
#134163 04/14/2006 3:24 PM
Well, if it is a 1952 the engine isn't original if it has a 283. Some A/C brackets like to use the front mounts on a small block. So if your 283 engine mounts are on the side all the better. You will also want heads with the bracket holes drilled in them.
