0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 6 Junior Member | | Junior Member Joined: Apr 2006 Posts: 6 | I just bought a 1952 5 window and looking for someone with experience in putting entire a/c unit in or have any suggestions?? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I don't have A/C experience but if your 283 has it's original heads on it, mounting brackets may prove difficult since they won't be drilled in the several locations for the compressor. You may have to put different heads on, Scott | | | | | Joined: Apr 2006 Posts: 6 Junior Member | | Junior Member Joined: Apr 2006 Posts: 6 | I don't know if the truck has the original heads, but I will be back in the states soon to find out!! | | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | The thought the early a/c compressors used a bracket that bolted to the exhaust manifold with 2 bolts.The adjustment bracket then bolted to a water pump stud ?
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
| | | | | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | | | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | I have a 64 belair with factory a/c still intact(on a 283). Compressor mounts on right side. It is about 25 miles from here, but i will be there this weekend. May try to take a look if wasps don't change my mind. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Well, if it is a 1952 the engine isn't original if it has a 283. Some A/C brackets like to use the front mounts on a small block. So if your 283 engine mounts are on the side all the better. You will also want heads with the bracket holes drilled in them. | | |
