4 members (Otto Skorzeny, 2-Ton, MNSmith, 1 invisible), 142 guests, and 3 robots.
Topics128,088
Posts1,056,114
Members48,434
#134059 03/16/2006 9:11 PM
Junior Member
Junior Member
I have a 55 first series 3100 with a 283 small block V8 and a 3 speed on the tree. I would like to change to an automatic transmission. Anyone have any tips or tricks on doing this or a list of parts needed or a source of information. Anyone done this before that could share their experience in time and difficulty.
Well, what comes to mind right off is, the trans itself, a flexplate and the bolts, a tailshaft cross member, a trans cooler, a starter, some sort of a shifter and probably have to rework your driveshaft too. I'm sure I'm missing something but you have a pretty good list to start with,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Should change the rear end ratio also, geared way to low for a auto.
Junior Member
Junior Member
Thank you for the information fellow bolters, this will give me a good start.
