| | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | Anonymous Unregistered | | Anonymous Unregistered | The standard high pressure hose from my donor car (G-body) will not fit in my current application so I need to have a hose custom made. Where can I get this done? The local parts houses are of no use for this. | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Look up Hydraulic Equipment in your local directory. One of the companies listed should be able to assemble custom lines or know who can. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I had mine done by a shop who specialize in steering & front end solutions for cars & trucks. Cost me around $ 60.00 for ( 2 ) hoses including fittings. | | | | | Joined: Mar 2004 Posts: 49 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 49 | I had mine made at a local napa part store. If you have the metel ends from your donor cars they can make a hydrolic line with compression fittings to fit the metal line ends that you cut off.I have a picture of the hoses from my power steering to my hydrolic brake booster at the bottom of my webshots page. Hope this helps. web page | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Go to your local parts house and see if a hose from the same era truck will somehow fit. My 48 has a pump from a Monte Carlo but the hoses and box from a 3/4 ton truck, Scott | | | | | Joined: Apr 2005 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 42 | See if there is a Parker hydralic hose distributor in your area. They will either be able to make you a hose or direct you to a shop that can make it. | | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | Made mine up from SS braided hose and fittings from Speedway Motors works great, Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There's a shop in Fort worth that makes them if you can't find one locally. Kim's Hose and Fittings, 817 332 8953. | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Where did you guys mount the PS pumps and how do you have your belts set up, if you are using an inline six?
I've got an alternator and a/c compressor on the manifold side of my engine and with the timing cover can't figure out where to put a PS pump!
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | 54 Just had this done for my 49 sub at a place called "Tubes and Hoses of Wisconsin". I think this is a national chain. Try the yellow pages for "Tubes and Hoses". They can make up anything you need. Mine was an odd setup using a boneyard mid 70s pump and a unit from an 84 GMC 1/2 ton. Can the Astros get past the Cardinals? Weeds | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Thanks for the responses. It seems there are a couple of local shops that can make up what I want if they have the correct fittings. The pricing though is higher than I thought it would be. The lowest is $25 for a High pressure line and the highest was $65. Compare this to $13 for a stock replacement hose. Oh well - everything else on this truck has been custom so why not this. Weeds - good to know you are still with us. Yes the Astros will be in the 100th Worlds Series once they get one more game from the cardinals tonight. GO ASTROS! | | |
