4 members (Otto Skorzeny, Wayne67vert, klhansen, TUTS 59), 74 guests, and 1 robot.
Topics128,051
Posts1,055,764
#1307 03/24/2005 12:52 PM
Junior Member
Junior Member
I've sprayed all sorts of penatrating (sp?) fluids all over my brake drums and pried and pulled on the drums and they still won't come off?! Anyone have any thoughts about getting the drums off? Thanks
Jason
1955 1st Series
Riding in the Passing Lane
If its the front you should remove the outer bearing & pull the hub/drum off together. You may have to back off the adjustment if the drum is grooved. If the rear drum is stuck to the axle you can go at it with a hammer & penitrating oil. Make shure there are no clips around the studs or rivets to the flange. If its bad enough you may have to heat the drum. Again back the adjustment up so ther is no interference with the shoes. smile
1972 Chevy c10 Cheyenne Super
A can of blaster,and a few sharp raps with a hammer should do the trick.On the rear.
Get a bigger hammer 3lb sledge! Hammer around the drum as if your were doing a 5 lug tire. More then likely it is rusted to the hub (this is rear). If it is the fronts see above.
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Not enough information- - - - -
Are you working on front or rear, 5-lug, 6-lug, or 8-lug drums? Some front drums are riveted to the hubs, and you need to remove the spindle nut and take hub and all off. Ditto on 8-lug 3/4 ton hubs, front and rear in some cases. On 8-lug rear hubs, the axle shafts must be removed by taking the 8 bolts out of the axle flange, hitting the center of the flange with a big hammer, and pulling the axle out. The spindle nut is accessible then. The 5 and 6 lug rear drums can be rusted to the axle flanges, and/or have deep grooves in the drums that trap the brake shoes. Some pictures, or a better description of what you're working on will help.
#1312 03/24/2005 11:28 PM
Junior Member
Junior Member
Not enough info huh? Well, the other guys seemed to help me out with the problem. I was leaving for work and I had to ask real quick. Now, if you must now, it's a 1/2 ton, 6 lug and all drums are stuck. Thanks guys!
Jason
1955 1st Series
#1313 03/24/2005 11:42 PM
Nice move, Jason.
I'm sure Jerry won't bother you with any more questions.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
Jason, you barking up the wrong tree. Jerry is one of the most helpful guy you never want to know.. :confused:
1965 C-10 Stepside
Junior Member
Junior Member
Ya know what, I really hate forums, because you ask a question and someone comes back with something like this and I said I was running late for work and this is what I get? Well, thanks for nothing!
Jason
1955 1st Series
There are at least 4 different situations that can result in the drums getting stuck to the point where they're difficult or impossible to remove. The removal techniques that work successfully on one type of drum will ruin other types. Since you seem to be unwilling to share some details without getting belligerent, we will be glad to help you out. Which way did you come in?
:rolleyes: :rolleyes: :rolleyes:
If you hate forums, why do you ask questions in them?? Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Is this like survivor? Can we vote him off?
You ask, they try to help. They give you the answer you need, you get [censored] and leave? You need to learn you lesson.
GO RANGERS grin
Photos Updated so check them out!
Whoa man! I don't get it. H.R.L. was trying to help you out and he's definitely one of the nicest and helpful folks you would wanna meet. Before I read "Not enough information", I was thinking the exact same thing and woulda wanted more info. I don't understand why that got you so bent.
I've not witnessed a single intent to be mean by anyone on these forums in the year I've been on. Perhaps a "Lighten Up!" is in order.
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
Ditto what Mugsy and HRL said. What's with the attitude?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
You have to remove the wheel first. wink
Gord
1954 1/2 ton 235 4 speed
I
I Offline
I used a large gear puller to put preasure on while the PB sunk in. I let it set a week with a litle more preasure and more PB and it finally broke loose.
I'll second the PB Blaster, patience, and banging on the rears to get them to budge. I didn't have ANY luck backing off the adjusters, mine were stuck fast.
Good Luck!
These are my favorite threads...
51 Chevy 1/2 ton-Restored
46 GMC 1 1/2 ton-Farm Fresh
#1325 03/25/2005 10:22 PM
Shesh! All this help is worth a fotune. You could be more appreciative. smile
#1326 03/25/2005 10:23 PM
That,s fortune. smile
#1327 03/26/2005 12:30 AM
I've found the best way to remove the drum is to kick it really hard, with no shoes on. Try that and get back to us.
1946 GMC 1/2 ton
1967 Chevy 1/2 ton
This old truck sure looks neat, but where are the heated seat controls?!?
Anonymous
Unregistered
Anonymous
Unregistered
Quote
hahahahahahahahaha.....
LeftEar55..sounds like you need to call your local dealer or a ride and figure it out tomorrow
Listen Jason -
Just go ahead and BOX THE DARN FRAME!! eek
