2 members (Rusty Heaps, PAUL Berardi), 140 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#1302095 03/07/2019 7:03 PM
Moderated
Moderated
New to the forum, but not old iron. My tastes do run towards South Bend's finest (Studebakers), but my wife inherited a '50 216 powered half ton, ex Air Force, or was it still Air Corps back then? someday we will have it back on the road.
My main reason for joining was for technical info. I have been rebuilding engines professionally for 32 years ( you get a masters degree,and you too can work in a machine shop! ).
We have 2, 235s in the shop now, a late engine that is going into a '52, and '44ish babbitt pounder. NOS military block and head, modifying the block to accept a late full-pressure crank. It fits a G506 ton and a half Army truck.
And a 289 Stude, 352 Packard, 7 Model T, 2 Bristol 6 cylinders, 2 '28 Stutz, etc, etc,etc
Welcome to the Stovebolt madness. There is no cure! shake
Welcome to the Stovebolt. You are now a member of the Texas Connection!
Glad to have you here and I'm sure you can contribute much to the discussions with you experience. Great guys here to interact with. See you around the garage.
Welcome to the 'bolt.
Please scroll through the various forums to see what they have to offer.
Make sure to check out the rules of the page as well.
Questions pertaining to your problem are welcome and will usually get answered quickly.
There are many "how I done it's" here as well that can be found using the search feature.
Another quality post.
Real Trucks Rattle
Welcome! Sounds like you have an interesting stable of vehicles. Lots of good Chev. info on this site.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
I too am interested in Studebakers though I never had one. Personal story: back in 1960 my folks wanted to replace their worn out 58 Ford so one day Dad brought home a new Lark to try out. We kept it a couple of days then Dad took it back, and they bought a new Rambler instead. For 50 years and more there have been no new Ramblers or Studes.
I am interested in your '44ish 235 crankshaft project. Please share with us the details. I imagined doing something similar in the past myself.
Welcome to the Stovebolt Madness!
Professional Novice
Moderator, Electrical Bay
Howdy from Dallas and welcome. I take it you have a shop in or around BCS? Our daughter and son-in-law got undergrad degrees from A&M by the way.
~ Jon
Big Bolt Forum Moderator
welcome to the site!
Mike
While you're whittling on that block, counterbore the rear main bearing cap area for this seal:
https://www.zoro.com/skf-shaft-seal-3-78x4-34x38-crwa1-nbr-38647/i/G9397674/
It eliminates the rope seal and stops that annoying drip from the flywheel housing dead in its tracks. I have a home-brewed mounting fixture for my Van Norman 944S boring bar that allows me to set up in the rear man bearing bore with the cats' paws and cut a square-bottomed counterbore the right size to press the seal into.
lol that's too funny....now I have an excuse....
