8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC), 104 guests, and 1 robot.
Topics128,060
Posts1,055,838
Members48,427
#1298793 02/13/2019 1:44 PM
Moderated
Moderated
Hello, I have a 1950 6400 and I could use some help sourcing the rear brake shoe springs.
6400 newbie #1298808 02/13/2019 3:20 PM
6400 Newbie, welcome to the Stovebolt. The 6400 sounds interesting and there is tons of help here on the Bolt.
However, since this is the Welcome Centre very few questions get asked or answered here. Please post your question in the most appropriate garage forum which would be the Driveline Forum or if your truck is a One Ton then perhaps the forum for the one ton's. You will get answers quickly that way.
Not sure what state Selbyville is in but there is bound to be some bolters close by. Watch post here as you participate and you'll likely find some close by.
.......* I will leave this post here and not move to another forum so that other bolters can welcome you. We are here to help so don't be bashful...no such things as stupid questions here.
6400 newbie #1298814 02/13/2019 4:41 PM
Welcome to the Stovebolt madness. There is no cure! shake
6400 newbie #1298815 02/13/2019 4:42 PM
Welcome to the 'bolt.
Please scroll through the various forums to see what they have to offer.
Make sure to check out the rules of the page as well.
Questions pertaining to your problem are welcome and will usually get answered quickly.
There are many "how I done it's" here as well that can be found using the search feature.
Another quality post.
Real Trucks Rattle
6400 newbie #1298922 02/14/2019 4:38 AM
Welcome!
I assume your 6400 is a 1 1/2 or 2 ton truck? If so, hop over to the Big Bolt forum and ask your question over there. Lots of knowledgeable people here.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
6400 newbie #1298939 02/14/2019 1:14 PM
Welcome newbie! We were all newbies at one time. Congrats on finding a 1950 6400. I would enjoy a big bolt if I had the space. A 6400 is a 161" wheelbase 2-ton. Look on the serial no./ data tag on the driver's door post. It should have the gross vehicle weight (GVW) and it's probably 16000. The original engine would have been a 235. Does it have a 2-speed rear axle? Grain box? PTO? Hoist?
Good luck. Some of the big truck parts are harder to find, but many times brake shoes can be relined. Springs and small parts may have to come from a salvage yard or truck dismantler who sells parts. You can post under Parts Wanted on the Swap Meet section.
Lots of scanned shop manuals and vehicle specifications on this website: http://chevy.oldcarmanualproject.com/shop/1948_51truck/index.htm Peruse around and look for the info you need.
Professional Novice
6400 newbie #1298956 02/14/2019 4:50 PM
Big Bolt Forum Moderator
welcome to the site! As Frank said, 6400 is a 2 ton. Brake return springs may be fun to find. I called brake and clutch in Seattle and got a part # for my 1958 6400. They are no longer made but, I was able to find some NOS springs online using the part # they gave me. I would start by posting in Big Bolts forum and see if someone has a part $ for you and then go from there. As mentioned, you may want to post in parts wanted if you don't get any help with part # in big bolts.
Just don't start a parts wanted thread in a forum other than parts wanted. It will get moved. (ok to ask for a part # or help on where to source parts though).
Mike
6400 newbie #1298959 02/14/2019 5:33 PM
When I need a hard to find part, I set up searches on ebay, craigslist and now the facebook marketplace.
Real Trucks Rattle
6400 newbie #1299144 02/16/2019 12:12 AM
Post some pictures. We all LOVE old truck pictures.
Professional Novice
