| | | Forums66 Topics128,268 Posts1,058,382 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | OK guys I'm sitting here looking at the truck bed sides, and front etc. well it all looks pretty simple, and I' wondering why I guy couldn't fabricate his own bed pretty easily? | | | | | Joined: Nov 2001 Posts: 12 New Guy | | New Guy Joined: Nov 2001 Posts: 12 | I've thought about it for quite awhile. I think the only hard part would be the rolled part on the top edges. I know alot of guys weld a piece of conduit to the top of the panel for this edge, but I've never seen the final results, and I can't picture it coming out all that well in my mind. I'll probably buy mine. Tucker | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | It can be done if you have the equipment etc but I would recommend Mack Products, a division of Mack Hils Inc out of Moberly Missouri. They do and excellent job and if you deal straight with them and cut out the catalog folks the price isn't so terrible for the good stuff you get. I purchase my 37 pickup as a complete assembly and in the long run saved $$$$ considering what I had to start with and what it would have cost to fix it! Call them up 660-263-7444..tell'em I said to call  | | | | | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | I'll have to call them and see...
as far as the edge, well in my scenario I don't even care if its round so I'd have more then one option on how I could finish that edge. kind of a few idea's I'm throwin around in my head. | | | | | Joined: Feb 2000 Posts: 5,265 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,265 | Mack Products get my vote to! I also bought a '37 bed from them, only I went and picked it up at the factory. They are about 100 miles from here. Saved a bunch on shipping. For about $1200 You get every nut, bolt, washer, side, stripe and some of the best looking oak flooring. For $200 or so more they will put it together for you. When you start pricing parts out, I don't think you can beat a kit!
If you have never worked with 14 gauge steel before, you might want to practice on some before trying to make a bed side. You don't just go cutting this stuff very easy. If you use a torch, it won't be flat when you get done. You really need a plasma cutter. You need the top edges rolled or something so the sides just don't flop around.
Just more to think about, Joe | | | | | Joined: Mar 2001 Posts: 77 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 77 | progressive stuff New Steel Bed Complete new steel bed with bed sides, header panel, stake pockets, rear crossmember, lower crossmembers, oak bed boards, steel bed strips, steel angle strips, stock tailgate and all needed assembly hardware, unassembled for shipping..............................PA-CTE-BED......$1450.00 For Stainless bed strips, add.............................PA-SS-BED......$125.00 For Smooth Tailgate, add.............................PA-SM-BED......$50.00
i thinkzz traveling along at terminal velocity will soon wear a body out. i will not die in shame if i never finish my dreams because my family iz my reality
can't wait until we can bed de ponys down, lite de fire, put on a big ol pot of coffee, and talk about how strong and brave our teams are.
bullfoot thinkszzzzzzzzzzz
| | | | | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | my bed sides aren't in that bad of shape, but I was just thinkin that it might be easier to actually build new sides, and sell the old one. I've looked at the pro's pick's beds too, and for the price I think these are the best deal out there. they aren't stock, but then I again for my applicaiton I don't car if its stock or not.
I do need the front, and the tailgate, but I want a full height tail gail with hidden hinges. there are a lot of parts that I'm trying to do on the economy side so I'll probably end up using what I've got. | | | | | Joined: Mar 2002 Posts: 4 Member | | Member Joined: Mar 2002 Posts: 4 | Hey mar-k.com sell bed parts or complete beds. They are in central oklahoma. Goose | | | | | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | I have made a bed for a 37 chevy had a metal shop bend the metal in a 8ft break bend and for the top on the sides for the roll i took a piece of tubing........plasma cut it the intire length slid it onto the bed side and mig welded it on. It was alot easier than trying to keep it straight while welding it by being plasma cut and slid on to the top. You would nee to see if you can get metal bent and plasma cut and it will make it alot easier to build
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
| | | | | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | you got any pictures of this bed? I would be really interested to see them? | | |
