4 members (DadsFirstPickup, BC59, Lightholder's Dad, Otto Skorzeny), 127 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
#1180612 08/31/2016 6:55 PM
Can anyone help me id my tranny in my 1957 6500? It is a 4speed with a 2speed rear end and a pto. The shift pattern is 1 3 R on top and
2 4 on bottom
If you really have reverse to the right and up, you have a New Process 5-speed and Granny is to the left and up!
New Process 5-speed pattern (optional in 1957)
1-2-4-R
..3-5
GM SM-420 4-speed pattern (standard issue)
...1-3
R-2-4
Dots/periods are just page space holders to keep the numbers liner up correctly...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks Mike, looks like I have some worn gears in there so time to pull and rebuild or find another.
So whats the answer...do you have the SM-420 or something else???
SM-420 will only have one PTO location (drivers side), the NP will have one on each side.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Matt,Sent A P.M.
Mo' Tater
C Online: Content
If you have reverse toward the dash, its a New Process 540 or 541. 1st is right next to 2nd and in kind of an awkward position. I drove one for 5 years. You may have a 5 speed and just haven't found 1st gear.
Crusing in the Passing Lane
And they are a great trans, you get a close ratio 4 speed with a 'granny' for starting out. I put one in an early Bronco behind a Buick 3.8 V6. Normally start out in second. 4 shift rails, so that is where each gear resides-on the end of each shift rail.
Ed
It's the NP540. You're right, I never use 2. Most of my driving I don't use the 2 speed cause I'm not going on anything fast enough
Moderated
Moderated
Hi. I have 1957.chevy 6500 5speed. Can not find reverse. Help. Thankyou.
3B Offline
Hy Kcfattts57, welcome, reverse will be in one of four positions, from neutral extreme right and up or down, or extreme left and up or down, hope that helps.
