0 members (),
100
Mod | | | Forums66 Topics128,080 Posts1,056,317 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Can anyone help me id my tranny in my 1957 6500? It is a 4speed with a 2speed rear end and a pto. The shift pattern is 1 3 R on top and 2 4 on bottom
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | If you really have reverse to the right and up, you have a New Process 5-speed and Granny is to the left and up! New Process 5-speed pattern (optional in 1957) 1-2-4-R ..3-5 GM SM-420 4-speed pattern (standard issue) ...1-3 R-2-4 Dots/periods are just page space holders to keep the numbers liner up correctly... Mike B  | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Thanks Mike, looks like I have some worn gears in there so time to pull and rebuild or find another. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | So whats the answer...do you have the SM-420 or something else??? SM-420 will only have one PTO location (drivers side), the NP will have one on each side. Mike B  | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | If you have reverse toward the dash, its a New Process 540 or 541. 1st is right next to 2nd and in kind of an awkward position. I drove one for 5 years. You may have a 5 speed and just haven't found 1st gear. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | And they are a great trans, you get a close ratio 4 speed with a 'granny' for starting out. I put one in an early Bronco behind a Buick 3.8 V6. Normally start out in second. 4 shift rails, so that is where each gear resides-on the end of each shift rail.
Ed
| | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | It's the NP540. You're right, I never use 2. Most of my driving I don't use the 2 speed cause I'm not going on anything fast enough | | | | | Joined: Nov 2018 Posts: 1 Moderated | | Moderated Joined: Nov 2018 Posts: 1 | Hi. I have 1957.chevy 6500 5speed. Can not find reverse. Help. Thankyou. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Kcfattts57, welcome, reverse will be in one of four positions, from neutral extreme right and up or down, or extreme left and up or down, hope that helps. | | |
