7 members (Bill Hanlon, fonz8261, latroca52, klhansen, JoergK., 1955 1 Series, 1 invisible),
110
Mod | | | Forums66 Topics128,195 Posts1,057,373 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | Does anyone have a any good way, or idea on how to make the inner/outer panel on a 1951 chevy 3100. Also does anyone have any dimensions for these things. thanks
Tony Jacques
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | What panel are you talking about? My first thought was door panels.
~Jim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | if your talking about the inner to outer COWL piece they do make repops but most of them suck! I sent mine back and took my OLD one to a guy who likes to do this kind of thing and he replaced half of mine that was bad for $25. The piece your talking about is usually around $55 plus shipping and as one bolter put it you have to "beat and bang it into submission" to try get it to fit. Good luck and if you can cut the spot welds off your old one and get it repaired you will be better off. I have not seen any "dimensions" anywhere and if there were some I'm sure a stovebolter would have let us know. This is one piece that is truly a B....... | | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | I got some replacement pieces, and like you said they don't fit well, I thought I might have just got some bad ones. So you are saying this a "custom" piece that will have to be formed to fit.
Tony Jacques
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | What you have to do with the repops is cut them where you need to, to make them fit and weld them up after. They have good steel in them but they don't have exactly the same shape. | | | | | Joined: Jun 2007 Posts: 95 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 95 | I've used the panels sold by Truck Shop (Orange, CA) for 5 years and they have held up fine. Yes, you do need to do some alteration, particularly if you are talking about the cowl panels. Overall the fit is pretty good, though.
J.D. Jordan
| | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | AHH...the infamous inner to outer cowl. I also ordered mine from the Truck and Car Shop. Doesn't matter where you get them, they won't fit. I had to fab mine a little bit also, no big deal. | | |
