4 members (GusG, carbking, 2-Ton, 1 invisible), 89 guests, and 2 robots.
Topics128,196
Posts1,057,386
Members48,469
#128723 10/19/2007 9:28 PM
Apprentice
Apprentice
Does anyone have a any good way, or idea on how to make the inner/outer panel on a 1951 chevy 3100. Also does anyone have any dimensions for these things. thanks
Tony Jacques
#128724 10/19/2007 9:38 PM
What panel are you talking about? My first thought was door panels.
~Jim
#128725 10/20/2007 2:55 AM
if your talking about the inner to outer COWL piece they do make repops but most of them suck! I sent mine back and took my OLD one to a guy who likes to do this kind of thing and he replaced half of mine that was bad for $25. The piece your talking about is usually around $55 plus shipping and as one bolter put it you have to "beat and bang it into submission" to try get it to fit. Good luck and if you can cut the spot welds off your old one and get it repaired you will be better off. I have not seen any "dimensions" anywhere and if there were some I'm sure a stovebolter would have let us know. This is one piece that is truly a B.......
#128726 10/20/2007 3:26 AM
Apprentice
Apprentice
I got some replacement pieces, and like you said they don't fit well, I thought I might have just got some bad ones. So you are saying this a "custom" piece that will have to be formed to fit.
Tony Jacques
#128727 10/23/2007 2:57 AM
What you have to do with the repops is cut them where you need to, to make them fit and weld them up after. They have good steel in them but they don't have exactly the same shape.
1951 1 Ton Completed
#128728 10/23/2007 3:03 AM
I've used the panels sold by Truck Shop (Orange, CA) for 5 years and they have held up fine. Yes, you do need to do some alteration, particularly if you are talking about the cowl panels. Overall the fit is pretty good, though.
J.D. Jordan
#128729 10/24/2007 10:45 AM
AHH...the infamous inner to outer cowl. I also ordered mine from the Truck and Car Shop. Doesn't matter where you get them, they won't fit. I had to fab mine a little bit also, no big deal.
