0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | I just received a pair of '39 Chev car taillights for my panel. Prior to ordering I searched and found good discussions on the topic of panel taillights. I was able to find the mounting template (thanks, Tim). At one point I thought I saw a template for the inner body support pad for the lights but have not been able to find it again. Is there one, or was I seeing things? Any clarification gratefully appreciated. Thanks
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | I don't believe there was an inner support pad. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 |
I didn't have an inner support on mine either. Rusty, be sure the mounting holes of your lights are the same as the template. They can be different. Some are above each other and some are side by side. | | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | The template is out about an 1/8 inch for one of the mounting stud holes, otherwise everything lines up well.
| | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | I found this on Jim Carter's site and it is for a light installed over the center of the rear doors for increased visibility at night. (See figure 79 and step 4) I did, however, find a thread from 2016 titled "Turn Signals for AD Carryall 1947- 1953." In it, jorb states towards the end of his post that "There is also a reinforcement plate that goes on the inside." I knew I saw something about an inner plate (rather than a pad) somewhere.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There was a reinforcement plate and a pad on each side. http://www.1954advance-design.com/DirectionalSignalsInstall.htmhttp://www.1954advance-design.com/Documents/Signal%20Install%2009.pdfHeed the grounding instructions - use a conductive anti-oxidant copper-impregnated (non-silicone-containing) grease on the clean bare holes in the body side panels. If you have lamps that have mounting posts that are off the holes in the template, you might have older auto lamps that look similar to the 47-55st panel-body lamps? My understanding is that there were also other similar auto lamps with mounting posts orientated 90 degrees differently. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Dangit. Now I gotta go back in there and make reinforcing plates. | | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | Thanks, Tim. I had trouble finding the first link again. So I wasn't seeing things! The lights I have are from Speedway and are for a 1939 Chev car. I got the tear drop shaped rubber gaskets (which line up perfectly with the mounting surface, holes, and studs of the lights) from The Filling Station.
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Yes there is a inner reinforcement plate for the bullet lights. I think the reinforcement plate in the Jim Carter LINK showing the upper roof light is the same reinforcement plate that is used on the side bullets. There are some optional ways to wire the bullet lights and the rear barn door light. You can read about the options in this THREAD | | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | Any one have an idea how thick the metal plate should be?
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | |
