2 members (klhansen, TUTS 59),
64
Mod | | | Forums66 Topics128,066 Posts1,055,873 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 57 'Bolter | | 'Bolter Joined: Mar 2015 Posts: 57 | on my 51 half ton i noticed what looks like a large standard screw driver slot can that tighten any play on the ball | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | ...click...Read on to step 4, on installation | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, that is called an end plug ("screw plug in figure 5). Have you adjusted them as described on that page - left column, under "1/2 ton and 3/4 ton, except Forward Control" Installation, step 4. That chapter has some confusing sections. If those end-plug fittings are loose (and/or extremely warn) that will affect steering and tracking. end-plugs in upper illustration | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Oops, my post is a repeat of DADS50's post - sorry, I got waylaid in the middle of my composing the post. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Better details on your post  If they were loose an inspection of the ball ends might be in order? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "If they were loose an inspection of the ball ends might be in order?"
Agreed | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | You will need to disassemble the ends, clean them thoroughly, and inspect the parts for any wear including the ball ends. If they are usable, make sure that you have a way of tightening the threaded ends very tightly until the springs bottom out, then back off until you can put the cotter pin one of the holes.
| | | | | Joined: Mar 2015 Posts: 57 'Bolter | | 'Bolter Joined: Mar 2015 Posts: 57 | im looking for ways to take some of the play out of the front end now that i have some insight i will pull the front tires and see if i can find the sorce of the play thanks to all | | | | | Joined: Mar 2015 Posts: 57 'Bolter | | 'Bolter Joined: Mar 2015 Posts: 57 | | | | | | Joined: Mar 2015 Posts: 57 'Bolter | | 'Bolter Joined: Mar 2015 Posts: 57 | | | | | | Joined: Mar 2015 Posts: 57 'Bolter | | 'Bolter Joined: Mar 2015 Posts: 57 | thank you that is on my list | | |
