4 members (32Fordpuchoptop, ‘37ChevyPU, Otto Skorzeny, 2-Ton), 105 guests, and 2 robots.
Topics128,050
Posts1,055,675
#1265257 05/09/2018 1:12 AM
on my 51 half ton i noticed what looks like a large standard screw driver slot can that tighten any play on the ball
shade tree #1265261 05/09/2018 1:34 AM
...click...
Read on to step 4, on installation
shade tree #1265263 05/09/2018 1:53 AM
Yes, that is called an end plug ("screw plug in figure 5).
Have you adjusted them as described on that page - left column, under "1/2 ton and 3/4 ton, except Forward Control"
Installation, step 4.
That chapter has some confusing sections. If those end-plug fittings are loose (and/or extremely warn) that will affect steering and tracking.
end-plugs in upper illustration
shade tree #1265264 05/09/2018 1:58 AM
Oops, my post is a repeat of DADS50's post - sorry, I got waylaid in the middle of my composing the post.
shade tree #1265266 05/09/2018 2:07 AM
Better details on your post thumbs_up
If they were loose an inspection of the ball ends might be in order?
shade tree #1265267 05/09/2018 2:09 AM
"If they were loose an inspection of the ball ends might be in order?"
Agreed
shade tree #1265359 05/10/2018 1:39 AM
You will need to disassemble the ends, clean them thoroughly, and inspect the parts for any wear including the ball ends. If they are usable, make sure that you have a way of tightening the threaded ends very tightly until the springs bottom out, then back off until you can put the cotter pin one of the holes.
tclederman #1265648 05/13/2018 2:19 AM
im looking for ways to take some of the play out of the front end now that i have some insight i will pull the front tires and see if i can find the sorce of the play thanks to all
tclederman #1265649 05/13/2018 2:21 AM
i will look tomorow
tclederman #1265650 05/13/2018 2:22 AM
thank you
tclederman #1265651 05/13/2018 2:24 AM
thank you that is on my list
