7 members (FAST55, 2-Ton, Reftys49, Eisenholtz, MickeyP, Oswald, Ponchogl),
117
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 96 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 96 | Getting ready to mount my 52 GMC Ambulance body back on the frame. Wondering if anyone has used solid polyurethane blocks instead of wood and rubber pad? Would the poly blocks be too hard, or break down? Would they need the rubber pad or be enough cushion without? Also, I'm not real excited about the carriage bolts that came with the kit from Carters (not the right blocks either by the way). Do you use a better bolt ie higher grade or SS or Size?
Thanks Richard | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'd use the rubber pad and I see no reason not to use the poly blocks if you want.........just my opinion. | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Wood or poly - use rubber pads on either. Wood is easier to shave down to make minor height adjustments. Poly is slick and may rotate over time. So I guess my vote is wood.
1951 Chevy Panel Truck
| | | | | Joined: Sep 2015 Posts: 96 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 96 | Good thoughts both. Can you tell me why the hole is off center? Why not a bigger block, then center the hole? Just wondering. | | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** In ref: to the wood blocks from JC ** I got the same mounting blocks from JC for my 53 Suburban when I compared them with the orig. blocks there was quite a difference. The orig. blocks were only 1 5/8" in height while the new blocks were 2" ** Maybe the new one's were that way for necessary adjustments along the way of getting the body mounted back on the frame. Cut all of the new blocks down to match the orig. one's on mine.
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Can you tell me why the hole is off center? Why not a bigger block, then center the hole? Just wondering. The offset blocks align with their corresponding mounts. I just used square blocks however. Either way, doesn't matter unless you're going for a points restoration. I got the same mounting blocks from JC for my 53 Suburban when I compared them with the orig. blocks there was quite a difference. The orig. blocks were only 1 5/8" in height while the new blocks were 2" ** Maybe the new one's were that way for necessary adjustments along the way of getting the body mounted back on the frame. Cut all of the new blocks down to match the orig. one's on mine. I was wondering if the blocks they sell are actually pickup bed mounting blocks? I had the same experience, and thanks to your advice I also cut mine down to 1-5/8 inches.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here are photos of the mounting blocks that I made, and where they are located.You will see that in one or two places I had to use radiator-mount-style "shims" to level-up the body on the frame. My original mounts also used that style of metal and rubber/fabric shims. I'll see if I can find an original block (and a spare "reproduction" block) in my garage, but I doubt that I will be able to find them. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Here is my old ones on my Panel.....maybe different than a surburban? Make my new ones out of Oak with 3 coats of preservatives and I made the cushion out of a big piece of fire hose which is rubber and polyester fabric layered together......just fyi. https://lh3.googleusercontent.com/z...HXrfRfnBV9QyFP0B8HCfJAmqIb=w1121-h840-no
