2 members (DadsFirstPickup, Stovebolt48), 97 guests, and 1 robot.
Topics128,050
Posts1,055,670
#1265109 05/07/2018 7:55 PM
Getting ready to mount my 52 GMC Ambulance body back on the frame. Wondering if anyone has used solid polyurethane blocks instead of wood and rubber pad? Would the poly blocks be too hard, or break down? Would they need the rubber pad or be enough cushion without? Also, I'm not real excited about the carriage bolts that came with the kit from Carters (not the right blocks either by the way). Do you use a better bolt ie higher grade or SS or Size?
Thanks Richard
~ Richard
1952 GMC Army Ambulance
"Building the Dream"
The story begins here in the DITY Gallery
Follow the build in the Project Journals
(If you can't wait, the "final pictures" and details are in Panels & Burbs)
First vehicle-1967 Chevy short bed pickup. Sold when got married frown | 1953 Chevy pickup restored-sold to purchase Toy Hauler trailer | 1964 GMC long bed Pickup 305 big block V/6 bought to restore with son and his 14 yr old son
I'd use the rubber pad and I see no reason not to use the poly blocks if you want.........just my opinion.
Wood or poly - use rubber pads on either. Wood is easier to shave down to make minor height adjustments. Poly is slick and may rotate over time. So I guess my vote is wood.
1951 Chevy Panel Truck
Good thoughts both. Can you tell me why the hole is off center? Why not a bigger block, then center the hole? Just wondering.
~ Richard
** In ref: to the wood blocks from JC ** I got the same mounting blocks from JC for my 53 Suburban when I compared them with the orig. blocks there was quite a difference. The orig. blocks were only 1 5/8" in height while the new blocks were 2" ** Maybe the new one's were that way for necessary adjustments along the way of getting the body mounted back on the frame. Cut all of the new blocks down to match the orig. one's on mine.
The offset blocks align with their corresponding mounts. I just used square blocks however. Either way, doesn't matter unless you're going for a points restoration.
I was wondering if the blocks they sell are actually pickup bed mounting blocks? I had the same experience, and thanks to your advice I also cut mine down to 1-5/8 inches.
Here are photos of the mounting blocks that I made, and where they are located.
You will see that in one or two places I had to use radiator-mount-style "shims" to level-up the body on the frame. My original mounts also used that style of metal and rubber/fabric shims.
I'll see if I can find an original block (and a spare "reproduction" block) in my garage, but I doubt that I will be able to find them.
Here is my old ones on my Panel.....maybe different than a surburban? Make my new ones out of Oak with 3 coats of preservatives and I made the cushion out of a big piece of fire hose which is rubber and polyester fabric layered together......just fyi.
https://lh3.googleusercontent.com/z...HXrfRfnBV9QyFP0B8HCfJAmqIb=w1121-h840-no
