1 members (Cosmo),
84
Mod | | | Forums66 Topics128,054 Posts1,055,779 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Wanting to install a 3 speed floor shift in my 56(3200) The trans. is out of a 55 wagon. What do I need to know to order the proper linkage etc. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | "back in the day" I used several of the "Foxcraft" kits but not even sure it they are available these days. They the cheapest you could find in the mid 50's! We use to end up breaking the stick off and fabricating one to our own lacking. | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Are the transmissions the same between car and truck? | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The simple answer is yes in those years. The difference is in the side cover in order to correspond with the shift arm/rods. Also the lower mount holes are threaded on the truck case. The car uses a plastic spedo gear, the truck is steel so the spedo drive gears are different sizes. Same internal components and gear ratios.
| | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Thanks,i found out the hard way about the side cover difference. | | |
