3 members (David Bush, GRNHydra, Leo), 69 guests, and 2 robots.
Topics128,060
Posts1,055,837
Members48,427
#1260754 03/30/2018 1:34 AM
Wanting to install a 3 speed floor shift in my 56(3200) The trans. is out of a 55 wagon. What do I need to know to order the proper linkage etc.
"back in the day" I used several of the "Foxcraft" kits but not even sure it they are available these days. They the cheapest you could find in the mid 50's! We use to end up breaking the stick off and fabricating one to our own lacking.
Are the transmissions the same between car and truck?
The simple answer is yes in those years. The difference is in the side cover in order to correspond with the shift arm/rods. Also the lower mount holes are threaded on the truck case. The car uses a plastic spedo gear, the truck is steel so the spedo drive gears are different sizes. Same internal components and gear ratios.
Midpiner #1260907 03/30/2018 10:42 PM
Thanks,i found out the hard way about the side cover difference.
