3 members (TUTS 59, Phak1, Pre '68 Dave), 196 guests, and 3 robots.
Topics128,095
Posts1,056,067
Members48,433
Hi there. I’m at a lose on what I should do next. I don’t have a good knowledge about the front end to really diagnose my problem. I have a 64 k10. There is a noise the emanates from the front left wheel area. The sound is intermittent while driving but mostly it makes the noise....which sounds like some rotating metal scratching or grinding. I checked the oil in the knuckle and it’s good; I took the wheel off and turned the drum and I could hear the sound. I adjusted the brake from loose and to tight and the noise continued. You don’t here the noise when your in neutral at a standstill. The noise will continue when I go through the gears but I hear it the most is anything over 15 MPH.
I’m hoping someone might have some thoughts to share base on this limitied info. Thanks john
1964 K10 Fleetside Pickup Truck
Could be a brake shoe keeper has come loose and is allowing the shoe to contact the drum. Or the brake shoes are just flat worn out (does it make more noise when you push the brake pedal?) I think you'll need to remove the drum and see what's going on with the brakes.
I took the wheel off and the brake pad is relatively new....with in the past two years. I also replaced the brake drums too at that time. The sound doesn’t change when I press the brakes. The sound is more of a “shooshing” noise. Do you think the drums need to be resurfaced? Appreciate the advice. John
I vote for something in the braking system. Two years is a long time in the truck world. Remove all 4 drums and inspect EVERYTHING. You will then either fix it or know to move on to another area.
Check your wheel bearings while you are at it.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Does anyone have some instructions related to removing the 4x4 hub locking mechanism inside the wheel hub? I removed the hub locking knob and pulled out the spring and locking spindle. There is a ton of grease in there. There is a small knobby protrusion inside the hub. I included some picture in the link below if it helps. I’m not sure what to do next in this process and given the amount of grease in there Is like to believe the bearings are greased up to but..... Thanks John.
https://app.box.com/s/1hlirdx2fmv93fvqb9yy1ykh6arutktw
Crusing in the Passing Lane
I'll bet if you Google Selectro with the MN if present, someone will have posted a U-tube video.
Ed
There should be a snap ring in the space between the splined ring you can see in your picture and the bearing hub proper. You'll probably have to dig around in there with a pick to find the space in the snap ring. Once that's removed, the outer ring with splines should come out. There may also be a snap ring around the axle, down in all that grease. If so, that has to come out also to remove the outer ring.
Good evening. I got my new wheel bearings and wanted to see if anyone was familiar with needing a specific “tool” to remove the jam nut? Or can you use a socket out of my kit to remove? Hoping to avoid needing anything last minute and with 9 degrees and snow, removing them to check really isn’t an option for me right now. Thanks John
If its the spindle nut your talking about a crescent wrench or a nice pair of channel locks will do the trick.....its all I ever use.
.....just be sure to take the carter key out.
So I’ve been searching for videos and other resources to help me get at the wheel bearings. I started again and didn’t get much further than removing the one snap ring I could find. After doing this I still cannot remove the windows to get at the bearings. I cannot find any other snap rings or nuts to remove. Can anyone offer any thoughts on next steps? The small spindle in the middle is where I removed the only snap ring I could find. The middle spindle moves backwards and forwards about 1/4 inch. I’ve felt around for a lock but but nothing. Is the outer spindle something that should be remover...the one that is closest to the hub? I’ve tried to remove this too but no luck. Any help would be appreciated. Ive added some additional pictures. Thanks John.
Moderator
Moderator
2 Offline
Looks like that could be a spiral retaining ring still in place.
They are a flat ring that overlaps.
https://www.gwkent.com/retainer-rin...HveTJtXAkwoUQQRY7nXXbPOTqjRoCzboQAvD_BwE
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Thank you. I tried looking for a retaining ring but didn’t find it. I went over the flat looking metal piece that surrounds the inner spindle and could not locate a seam. I also went over the outer spindle closest to the metal hub and nothing. The inner spindle has threading to accept a bolt or something as well. Not sure if that is useful.
After looking at this again in a different light I saw the flat retaining ring. I was able to remove that from the outer spindle and metal hub. I feel like the outer spindle should slide out but it doesn’t. I’ve hit the hub with a hammer a few times. But am reluctant to hit it too hard to hopefully free it up.
Moderator
Moderator
2 Offline
The spline probably has a few burrs where the ring was and will not engage the outer spline.
Use a square end Precision file and gently file the burr down
Harbor Freight has them for 4 bucks.
But do not force it, wiggle/tap and see if you can get those burrs back down.
If you don't have the files, we need HR Jerry to give advice.
Hope this helps and let us know the outcome.
Don
"The Flag Pole"
1953 1-ton pickup
I don’t see where there are any burrs. In the picture I labeled that area as #1. The metal hub acts like a lip where the inner gear cannot come out. It seams as if the entire metal hub had to come off to access the gears and bearings. I’ve tried everything to see what could be holding this together. When looking in the Center spindle #2 I can see threading. I’m wondering if you have to use a device like a steering wheel remover etc to remove that gear? Not sure why that would be threaded otherwise.
https://app.box.com/s/0vl33xiyem9ps9zfpzf8s1i60ppp30vo
Before i possibly messed something up I figured I’d check. Thanks John.
Hard to tell from the photos, but is the outside part of the splines on the part on the shaft the same size as the inside splines on the hub? Maybe they have to line up to get that piece out. In other words, would pulling piece out lock the axle to the hub? Not sure how you'd get it pulled out if that was the case however as there doesn't appear to be anything to grab on to it.
Are you sure there's no snap ring holding that larger splined piece to the hub proper?
