| | | Forums66 Topics128,195 Posts1,057,376 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I recently discovered that some of the '51's old paperwork listed the truck's original license plate number. I found a company that reproduces license plates and thought one with the original number would be cool. The only problem is that they sell car plates that are marroon with silver numbering. I am certain that truck plates were a different color, but i have no idea what color since they used to change from year to year. Also, I know that cars had a set of two, but I don't know if the trucks had a set, or if they only used one. Any guidance is greatly appreciated.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | There are TONS of tag collectors, do a Google search and see what pops up or call your DMV and ask them what the official colors were... Mike B  | | | | | Joined: May 2015 Posts: 11,184 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,184 | What Mike ^ said. Just for giggles I did a search on eBay for "1951 Missouri truck license plate" and didn't find a coresponding plate. The colors were all over the place. I did find an "Antique" 1992 MO plate, however.  There ought to be a law against that. That would make me almost a triple antique, I guess.  On edit: here's a wikipedia article that should help you out. Missouri Plates
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2001 Posts: 3,619 Moderator | | Moderator Joined: Aug 2001 Posts: 3,619 | 8Track I remember the maroon and silver Missouri tags. May even have a few. But going back to 51 is before my time. But I have an 8-Track player somewhere. Do you remember the 4-Track player?
Also, do a search for my location, we should not be very far from each other. Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | Now this sounds familiar. A couple years ago I decided I'd like a 1951 plate to mount on the front of my truck, mistakenly thinking I'd get fewer "what year is it" questions (no change). It was sorta enjoyable checking all the dusty boxes and bins in junk and antique shops.....no luck. Finely found a very nice plate from an Ebay seller in of all places, New York City! As I recall it was a bargain at $25. Some online sellers were getting $75 for similar plates.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | Thanks for the ideas.
Mike - Google shows me that 1951 Missouri truck plates must be as rare as hen's teeth. I can find nothing. I haven't tried the DMV route yet. They are less than helpful most of the time.
Kevin - I agree that a 1992 plate is far from antique. That reminds me of the time I saw an early 90's Mazda Miata running around with Historic Vehicle plates.
Don - I do remember seeing 4 tracks over the years, but I have never owned one. They are still somewhat of a novelty or mystery to me. 8 tracks on the other hand... As far as my location, maybe I should revise my it to read South Central Missouri. I'm in Rolla. Definitely not far away at all, but I don't get to your neck of the woods too often.
Mopar - I have found a few examples of the '51 car plate. I'm not sure if Missouri will let you use a car plate on a truck or not. I was really hoping to have one custom made, since I know what my original license number was from 1951. Without seeing one, I have no idea what color they were, if and where they noted the licensed weight and if they were single year or multiple year plates with tabs. Maybe this is more work than it is really worth. I do enjoy a little bit of the thrill of the hunt, but after a while...
| | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | In '37 Missouri had three or more plates. There were two car tags, one is much bigger, and truck only plates. I could not find two truck only, so I use the bigger car tags on my truck. The DMV doesn't care as long as the plate numbers are not in use. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Rolla eh? We had a VCCA tour based out of Rolla a few years ago. Neat area, we had a good time.
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | I would check to see if you can use car plates, because here in Ontario we can, if the number/letter sequence isn't in use. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .... I say don't tell them anything. When/if they let you run YOM..."year of make" just take them the tag! Probably not that easy but its work a try. You may just get the one lady, or gentleman that does the job! | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | I think that's Year Of Manufacture but who's picking nits.......
