| | | Forums66 Topics128,118 Posts1,056,302 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2016 Posts: 41 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 41 | Hi, I have a short bed stepside truck and using an aftermarket chassis. I already sold me original frame. Can anyone provide the dimensions between different mounting holes on the frame? Specifically: from the front cab mount to the rear cab mount Front cab mount to the front bed mount Front cab mount to the rear bed sill mount
Thanks in advance. | | | | | Joined: Jul 2016 Posts: 41 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 41 | Thanks. I've tried that but doesn't have the info I need. | | | | | Joined: May 2015 Posts: 11,070 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,070 | Here's some frame hole dimensions from the FAM All referenced from the front of the dash. Front Body Mount - 13.186" Rear Body Mount - 50.186" Front Bed Mount - 62.75" Rear Bed Mount - 133.688" (this is the rearmost hole in the frame.)
Hope that helps.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2016 Posts: 41 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 41 | Just what I needed, Thanks! | | |
