1 members (Gray_Ghost), 77 guests, and 2 robots.
Topics128,128
Posts1,056,358
Members48,441
Hi,
I have a short bed stepside truck and using an aftermarket chassis. I already sold me original frame. Can anyone provide the dimensions between different mounting holes on the frame?
Specifically:
from the front cab mount to the rear cab mount
Front cab mount to the front bed mount
Front cab mount to the rear bed sill mount
Thanks in advance.
Maybe this will help?? 1/2 ton may be the same up until 54 but not positive.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0202.htm
Thanks. I've tried that but doesn't have the info I need.
Here's some frame hole dimensions from the FAM
All referenced from the front of the dash.
Front Body Mount - 13.186"
Rear Body Mount - 50.186"
Front Bed Mount - 62.75"
Rear Bed Mount - 133.688" (this is the rearmost hole in the frame.)
Hope that helps.
Just what I needed, Thanks!
