3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#1248087 12/25/2017 1:27 AM
my 1937chevy rear leaf springs have a smaller set mounted above larger set is this normal for 1/2 or 3/4 ton trucks? thank you all in advance.
The “overload” springs, above the usual leaf springs, were an aftermarket addition used typically on 1/2 ton trucks . These were, as far as I have been able to determine at least yet, not sold as a Chevrolet accessory. None are listed in the accessory catalog or master parts catalogs. I’ve seen these on some trucks used by farmers. My ‘46 Chevy 1/2 Ton had them too.
J C Whitney?
back yard wrench turner
My '38 1 ton had them. I took them off, must have weighed 40lbs each side.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Built a 37 for a local friend a few years ago and 1/2 ton 37 had those overload springs on it. We left them because he wanted it "just like he found it". I never checked but wondered if it was a RPO but I guess not.
Mine had them and a few pictures of similar trucks have them. Who ever was selling the springs, sold a bunch of them!
JC Whitney?
thank you again good info. not only am I trying to learn as much as I can about this old girl also trying to tell physicaly 1/2 or 3/4 ton . po says its a 1/2 ton with extended wb from factory. serial plate says 3/4 po says he thinks been changed in past appericate any and all info how to tell 1/2 t from 3/4t 1937 chevy truck.
Crusing in the Passing Lane
Half ton trucks generally have 6 lug wheel, 3/4 ton, 8.
Ed
Ed
My '38 1 ton has 6 lugs.
Wayne
1989 Silverado
How wide is your frame at the rear? Here are the specs.
1/2 ton's are 46 inches wide. My '38 1 ton is 36 inches wide.
Wayne
1989 Silverado
the oldgirl has 6 lugs .wheelbase falls in line with 3/4ton. don't know if extended w.b. from factory for 1/2 t or not?po seems to know quite a bit about older cars/trucks has a 8000 sq. ft. wharehouse in pa. filled w/vechicles.verifed by transport owner/driver with pic.s. but no one knows everything. by the way po relly good guy .also is looking to let go ofsome of his toys.
Really doubtful the factory would extend the frame when they already had a longer one to start with.
sorry everybody for falling off grid . had surgery when this thread started , pushed it ended up with a extended stay laying in a bed wearing a backless gown. now the wife has approved light duty. so I will be able to answer questions tomorrow . thanks again
hello nasty day today but squeezed in a little time . could not find any info on smaller helper springs and the outside to outside rear frame measurement is 36" wide
