1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2017 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2017 Posts: 51 | my 1937chevy rear leaf springs have a smaller set mounted above larger set is this normal for 1/2 or 3/4 ton trucks? thank you all in advance. | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | The “overload” springs, above the usual leaf springs, were an aftermarket addition used typically on 1/2 ton trucks . These were, as far as I have been able to determine at least yet, not sold as a Chevrolet accessory. None are listed in the accessory catalog or master parts catalogs. I’ve seen these on some trucks used by farmers. My ‘46 Chevy 1/2 Ton had them too. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2010 Posts: 1,707 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,707 | My '38 1 ton had them. I took them off, must have weighed 40lbs each side. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Built a 37 for a local friend a few years ago and 1/2 ton 37 had those overload springs on it. We left them because he wanted it "just like he found it". I never checked but wondered if it was a RPO but I guess not. | | | | | Joined: Feb 2000 Posts: 5,216 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,216 | Mine had them and a few pictures of similar trucks have them. Who ever was selling the springs, sold a bunch of them! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2017 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2017 Posts: 51 | thank you again good info. not only am I trying to learn as much as I can about this old girl also trying to tell physicaly 1/2 or 3/4 ton . po says its a 1/2 ton with extended wb from factory. serial plate says 3/4 po says he thinks been changed in past appericate any and all info how to tell 1/2 t from 3/4t 1937 chevy truck. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Half ton trucks generally have 6 lug wheel, 3/4 ton, 8.
Ed
| | | | | Joined: Sep 2010 Posts: 1,707 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,707 | Half ton trucks generally have 6 lug wheel, 3/4 ton, 8.
Ed My '38 1 ton has 6 lugs. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Sep 2010 Posts: 1,707 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,707 | How wide is your frame at the rear? Here are the specs.1/2 ton's are 46 inches wide. My '38 1 ton is 36 inches wide. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Dec 2017 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2017 Posts: 51 | the oldgirl has 6 lugs .wheelbase falls in line with 3/4ton. don't know if extended w.b. from factory for 1/2 t or not?po seems to know quite a bit about older cars/trucks has a 8000 sq. ft. wharehouse in pa. filled w/vechicles.verifed by transport owner/driver with pic.s. but no one knows everything. by the way po relly good guy .also is looking to let go ofsome of his toys. | | | | | Joined: Feb 2000 Posts: 5,216 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,216 | Really doubtful the factory would extend the frame when they already had a longer one to start with. | | | | | Joined: Dec 2017 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2017 Posts: 51 | sorry everybody for falling off grid . had surgery when this thread started , pushed it ended up with a extended stay laying in a bed wearing a backless gown. now the wife has approved light duty. so I will be able to answer questions tomorrow . thanks again | | | | | Joined: Dec 2017 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2017 Posts: 51 | hello nasty day today but squeezed in a little time . could not find any info on smaller helper springs and the outside to outside rear frame measurement is 36" wide | | |
