Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
0 members (), 470 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
Stovebolt Photo Moderator
Good Morning,
I am installing new glass in the doors of a 47 AD. The window edge trim around the perimeter of the glass attaches to the window regulator hardware with a "male/female" screw setup. I've been able to make and improvise just about all the hardware on the truck. This one stumps me, as it is so small and flush with the trim. Anything that would stick out proud would keep the window from traversing the channel. I'm almost thinking to put a slight weld between the 2 pieces. Or at least ask my buddy...........I can't weld.
Anyone come across this situation? I don't imagine there is a source for the screw setup. I was able to remove the old clutch head and female receiver.
Thanks, any suggestions would be appreciated.
Joe
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
Do a search for rivet nuts.
Threaded rivets.
Give me ambiguity
or give me something else
Thanks - I will try that.
Sir Searchalot
Sir Searchalot
Maybe something like one of THESE.
classicparts.com has those screws/sleeve nuts. Part # 70-811. $4.95 enough for both sides.
Sir Searchalot
Sir Searchalot
Good find Carl!!!!!!
Too bad I didn't find that source before I made my own on my hillbilly lathe. Cordless drill and bench grinder, that is. It only took me 3 times and most of a day to get it right.
Sir Searchalot
Sir Searchalot
It's OK, good experience and UPS does not deliver to Butcher Holler anyway.
Joe, do you know someone who works in a body shop? I had a friend who does all sorts of restorations who had the tool to put them in and had a supply of the rivet with the kit. I'd think most shops would have one.
(I needed the rivit nuts on my door panel) Worked like a charm.
It ain't no fun climbing the telephone pole with my laptop to order stuff neither.
I'm still proud, however not of being a coal miner's daughter...
Haunting the SBP since 2001
Those are them - great find. I have to start reading my catalogs again.
Sir Searchalot
Sir Searchalot
Sooooooooo.............nobody read that Carl already found them? About 4 days prior to last post?
Moderated by  ndkid275, Phak1
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.076s Queries: 14 (0.071s) Memory: 0.6546 MB (Peak: 0.7518 MB) Data Comp: Zlib Server Time: 2025-09-22 08:57:06 UTC
Valid HTML 5 and Valid CSS
